whos layin body?!
nine5yukon
baton rouge
i know its been done, someone show me a t/y, preferrably 4dr on the ground and explain how ya got it there.
saw one in greenville that removed the lower 2" from the frame, tubbed and notched into the rear cabin and used a 2dr fuel tank for clearance.
is that the easiest way?
Lifted99Yukon
Kansas City, Missouri
There are so many ways. Everyone has their own style/way to lay a SUV out. It's not "easy" persay. You have alot of floor to cut out for a Body Drop.
Here is one, thought I had others saved
Stock Floor is better IMO. Lots of rear floor cutting, tubs, etc. Better to use a Fuel Cell, you can have any size, and put it anywhere you can. I'll dig around for pictures/info.
At one time, my Yukon was planned for a Stock Floor at a local shop called Sick Side Customs. The owner is the builder/owner of Plane Jane.
Here is my favorite stock floored Tahoe
[yt]2Bk1xQZNaBg[/yt]
And what do you mean by "Removed the lower 2" of Frame"
You dont remove any of the frame. Either you do a Stock Floor Body drop with building a new frame. Or you do a traditional body drop by cutting floor, lowering it, channels, etc...
Only a few ways to do it.
N
nine5yukon
baton rouge
i mean, they took 2" off the from wheel hump to wheel hump \_______/
they stripped the wiring/lines from the inside of the frame rails, welded in 2" box tubing 1/4" wall from hump to hump two inches from the bottom, then plama cut the bottom off level with the rockers.
that allowed the body to lay flat, instead of sittin on frame and the rockers waaay up in the air.
im aware a fuel cell would be a better choice, they just said they used a tank from a 2dr, guess it was readily available.
also, i have no problem cuttin the floor from the cowl to the barn doors, just wanna see whos done it and what they ran into doin it.
dont mess with texas, those cats are from another country and seriously get down!!!
Lifted99Yukon
Im sorry, but Im not following what they did. Sounds like they just boxed in the factory frame, then cut the bottom of the frame itself?
How did they do the body? They had to do a traditional body drop, lowered the body mounts, or made new ones. But if they cut the bottom of frame, then the mount would have no where to go.
I am sure you mean they did a 2" Traditional Body Drop. Not changing the frame, but dropping the Body itself 2", raised floor 2" or more with channels etc...
---------- Post added at 08:32 AM ---------- Previous post was at 08:00 AM ----------
I guess I did have some on my imageshack.
Rear setup
N
nine5yukon
baton rouge
the way it was explained to me, they removed two inches from the lowest part of the frame. crazy sounding i know but the body was not dropped, no cuttin into the floor. the bottom few inches was removed then they just laid frame and tubbed the rear, like you posted above but instead of just laying frame, it lays rockers too. no bd
:deal:
Young28
The Yukon God
ga
hmm that is an interesting way to do it. So if i understand this correct they bagged it to lay frame, then they trimmed the frame 2" to make it look bd without bodying it.
N
nine5yukon
baton rouge
actually, they trimmed it 2" to match the body, then laid frame. doin it the other way would sit 2" high after trimming.
Lifted99Yukon
I'm sorry. But that is a terrible, ghetto way to get it done. Even if it boxed. Just a stupid idea IMO. Hope they didn't do that to alot of trucks.
How tall is the actual frame is what I want to know. I cant even grasb someone really thinking of doing that.
N
nine5yukon
baton rouge
the OEM frame is 7"+ across the bottom, it narrows to 5.5" in the humps and ends at 4.5" behind the axle
so if you trim off the lower 2" and box it, itll still be 5" across the bottom and imo stronger than the oem open frame rails.
groundscr8pr
flaccid member
scarborough maine
i had a stock floored 4 door. we built a new frame from the firewall back out of 2x4 1/4 wall box tubing. used a 94 s10 blazer gas tank. raised rear floor and trans tunnel. and tubbed back and firewall.
ur2nvs
I understand exactly what he's saying. They did a stock floor, with out removing the body. Pretty common way of doing it on OBS trucks.
MOBmentality
Has a $25,000 Punch
Lifted youre looking at the wrong part of the problem.. IF there are vehicles that can be dropped like this just by trimming the frame and boxing it in then its not unsafe or ghetto at all.. its damn near perfect.. and i wish we all could do it.
BUT the issue is if there are vehicles you can do this on the list is SHOOOOORT
because the bottom of the frame has crossmembers and racks and all kindsa shit.. fact is.. the frame isnt the lowest part on almost ANY vehicle..
hell even if you took the tires , wheels , crossmember , rearend and transmission out of a c10.. it still wouldnt ACTUALLY sit on its frame rails..
same with an s10.. and a NBS yukon
we are talking a crowded ass area..
THEN .. even if it COULD sit on frame rails without removing all that.. once you cut off an extra 2 inches.. not only do you run into more shit.. but now running proper mounts might not even be possible..
or if you were laying frame already.. would you be on the oil oil tranny pan? would 2 more inches lay you on it?
The easy answer to this is lift the motor and tranny 2 inches.. but thats its own set of work..
and THEN what about steering racks and controls?
SO its not the trimming the frame thats dumb.. it would be dope as **** if it were that easy.. its just .. not..
And if there are some trucks it WILL work on .. then more power to the geniuses doing $5000 body drops for $1000
tumminellon
just got done mine ...took the rubber out of the body mounts then trimmed what ever hung below doors.
2lnblktop
This method sounds like a simple idea and looks goos on that hoe but it kinda concerns me.
---------- Post added at 12:42 PM ---------- Previous post was at 12:20 PM ----------
just finished mine
photo.php
---------- Post added at 03:02 AM ---------- Previous post was at 03:01 AM ----------
photo.php
---------- Post added at 03:03 AM ---------- Previous post was at 03:02 AM ----------
add me on facebook rob robolicious melendez
---------- Post added at 03:04 AM ---------- Previous post was at
03:03 AM ----------
http://www.facebook.com/photo.php?pid=5513973&l=1d53fa625f&id=525786172
Did you bd yours the same as they are talkin by loosin the bushings and trimming the bottom of the frame?
vsaravia
