tybardy
everyone needs a Hoe
I was just curious because there is another thread about how much lift the Z71 coils give you over stock and I thought it was only about 1/2"... Good to hear though!
just installed bilsteins w/ shock extenders... I will give my opinion shortly... I know I am lowered, but with the shock extenders, I should experience the same range of motion (kinda)
I like it! BTW, what size wheels/tires are you running. the set up in your sig looks pretty beefy. I like the lip on the wheel plus the amount of sidewall you've got on the tires I like it! BTW, what size wheels/tires are you running. the set up in your sig looks pretty beefy. I like the lip on the wheel plus the amount of sidewall you've got on the tires
I am running 305/50/20's on 20 x 11 (I think they are 11, could be 10.5) and I am not 100% sure on the offset, I will pull a few measurements when I do the front spindles and shocks, probably next monday, possibly tomorrow.
The tire/wheel combo sets off pretty nice on the drop I have. They are tubbed out quite a bit, if I did not have the fender flares, the wheels would be sticking out past the fenders by quite a bit.
Brown truck came today...
Installed my new black DEPO headlights and black turn/DRL lights to tie in with the previously smoked emblem...pic simply does not do it justice!
@tucsonlocal - you were right...these are sweet!
