bahollis
Lead Foot
TEXAS
Got my battery replaced under warranty, and discovered I did not need to buy a new alternator.
Now I have time to research for the correct alternator if it ever does crap out!
BH
thumper_ehhhhh
Canada ehhhhh
BH
Check your rpo codes it should tell you what alternator came with your truck from the factory.
Ced
Painted and put in a 03+ console.:)
how did you prep it to get da paint to stick?
---------- Post added at 02:39 PM ---------- Previous post was at 02:38 PM ----------
ha ha..... i notice b/c mine keeps coming off. Make sure you glue it down if you dont want it coming off everytime you open it. lol...
i have one, but dont think its worth shipping..
do you want to sell it?
solored
canada
Well got a decent deal IMO.. Posted a pic in ym other thread but it wasnt relitive to the topic of the thread.. SO I post pic here! Cant wait to get home to put this in.. I only got it because it was a good deal, wasnt going to go this route at all. The amps and the rack I wont be using, the box and the subs I will. Might try and see if I can put 2 more 10s of the same JL subs in there. Or maybe put the w7s in there. The box measure 38x12x12 so I have 10"s of space to fill 5" on each side. So I will build some nice little vinyl caps and fill the open sides up to make it look all flush and clean when its put inthe back of the truck.
I got ALL of this stuff in the picture (including wiring, that I wont be using lol) for the winderful price of 120$ cdn.
bahollis
Lead Foot
TEXAS
Naaahh, I mean I will upgrade the alternator to a higher amp output, but now I have time to research the best brand.
Thanks though.
06xl
MD
Flushed motor an converted to mobile 1 fully synthetic with mobile 1 filter,sparyed uncarriage rust proof black and removed all badges an getting them ready to black an replace
bahollis
Lead Foot
TEXAS
I installed LEDs for the front & 2nd row floorboard areas. They're the LEDs I got from HIDGuy for my vanity lights. I could never get them to work correctly with the rest of the dome light setup. I have a voltage issue in my dome light system, which I think is a bad dimmer/on-off switch... I guess. I gave up on that and put the OEM vanity lights back in. No issues any longer. (just to be clear, it's not his lights causing the problem. I have lights from superbrightleds.com that did the exact same thing, I just used his for my custom setup because they are freaking bright)
I had originally designed it so the Floorboard lights would turn on and off with the main domes, but when they would come on ALL of the LEDs were about 20% brightness. I instead installed a rocker switch down under the dash on the driver's side so they can be operated independently from the domes. The rocker is completely hidden, and had its own in-line fuse. The wiring is all heat shrunk together into a nice clean harness, and run under the heat delivery tube up front, and under the center console and mounted under the seats for the 2nd row.
It's a nice thing to have when a toddler drops their drink or their toy on a long trip, and you gotta find it before they lose their minds and go *******.
(you young bloods out there just wait!)
BH
andrewmoore13
not today but recently...
equivalent of flowmaster super40 dual exhaust
angel eye project headlights
clear corner lights to match
new grille
cracked front bumper and hood doesn't quite sit all the way down. :(
scarpi
Phoenix, AZ.
Recently washed and waxed. Still looks like new and runs great at 50,000 miles. Love my 02 Yukon. It will take me anywhere.
97transam
Antenna delete. I had just straighten up and cleaned the garage so I knew where all the tools were. Presently just laid the antenna along the fender through the hood bumper stop.
Merch619
