Finally got my Esky cluster....but need opinions
NJ04HOE
Paterson, NJ
Hello all,
Like the title says I finally pulled the trigger on the Esky cluster since mine started acting up about a month ago. There's just one small problem, I ordered the 05-06 cluster and they sent me the 03-05 cluster. There's not much of a difference except for the shift indicator. Btw, this was a $300 purchase with a $200 deposit (which I get back when I send them mine)
Now here's the question....Should I hold off on putting it in and wait until moday when they open to complain and send it back for the right one or just keep it and put it in now?
Here's the one I ordered (05-06)
And here's what I got (03-05)
chistoso
Arizona
You paid big coin for it it's only proper that you get what you paid for. The top cluster looks cleaner IMO.
If you're in no rush I say send it back.
solored
canada
id get the one you ordered, that way it should a direct drop in with everything working the same way as the factory to your truck one did.
Tahoewhat
Ballin' on a Budget
TX
Get the correct one. That way it all works fine. Unless it will work fine, then id keep the one you got. BUt honestly if it was me, id be calling monday and sending it back and ordering the right one.
but those look good. I thought they were blue.
NJ04HOE
NJ04HOE
Paterson, NJ
Yeah that's what I was thinking, I'm just going to wait since tomorrow is monday.
Thanks, they both are plug & play and would work the same. I'm more concerned with the look.
They're actually listed as silver face with white gauges and white pointers, I wanted that color scheme because my interior is all gray.
chistoso
Arizona
This is exactly what I was thinking when I had my Tahoe. It's gonna look and match perfectly. It's gonna bring the dash to life..
Tahoewhat
Ballin' on a Budget
TX
Going to look good. If you dont mind, where you get it from?
NJ04HOE
NJ04HOE
Paterson, NJ
Ebay, the sellers name is Digital Dash Solutions
Oh by the way guys, I spoke with them today and they sent out the correct cluster today and I just have to send them the wrong one back then send mine in for the core refund ($200)
Thanks for the opinions
VT19
i like the first one better, it looks cleaner, smoother and i like the shift selector
Travieso
Boooooooost !
Los Skandeles, CA
Very nice previs can't wait to see this cluster installed. this is probably my next mod, i need to look at something nice other then the old plain gauges of ours.
NJ04HOE
NJ04HOE
Paterson, NJ
Thanks, here's a phone pic I took last night after I put it in....
vyper202
How hard was the install??? Any issues or special tools needed?
Travieso
Boooooooost !
Los Skandeles, CA
so NJ04HOE you only came off of pocket 100 dollars right since you turned in your old one for 200 correct? also how did they go by putting in the right information on your cluster did you have to do yourself via the internet/computer ? im curious on how this works
chistoso
Arizona
Junior, any speedo shop can do it for you. I had mine done on my Tahoe for around $45 at a local speedo shop. Be prepared to take in your old cluster if you go this route, they will need to plug yours in to verify the DIC info and transfer it to the new cluster otherwise you'll get into a heep of shit if you were to try and sell it. Info has to match what the computer will read..
Tahoewhat
Ballin' on a Budget
TX
looks really good. how does it look in contrast to the interior? i thought about doing a ss cluster, had the chance, but the white just seemed to much. never put it in though..
loooks realy good
NJ04HOE
NJ04HOE
Paterson, NJ
Install was very easy. You just have to take off the dash bezel, lower the steering wheel, apply the parking brake, put the truck in gear 1 to lower the shifter out of your way and then take out the four bolts (8mm I think) and unplug the one harness on the back.
Actually I came out of pocket with $300, the total was $500 but you get $200 back once they receive your cluster. They have you fill out an odometer statement with your mileage, vin # and engine hours fax it to them and they put the info in the new cluster. It took about 6 days total because of the mix up so I called them back with my new accurate info and by the time the 2nd cluster got to me my mileage was only off by about 50 miles and they advised me that it wasn't enough to cause a problem in the future if I sold the truck or something like that.
loooks realy good
Thanks, I actually like the contrast. It's not like a bright bleach white it seems more like a light silver to me.
dizhai
