turbo set up?
z71tahoe
columbus ohio
well im really a noobie because i just posted this in the 2007+ lopl but anyways I bought my tahoe last fall but I wanted to know if there are any good turbo kits out there for a decent price and for anyone that has done that to there tahoe what did you all need to mod. to the motor also what would be a good boost setting not wanting to run 9 sec but a good time like mid 12s thanks
---------- Post added at 08:15 PM ---------- Previous post was at 08:14 PM ----------
by the way its a 02 z71 with a 5.3 in it
stevo-nine
I am also interested in some info I just picked up an 04 5.3 tahoe. I found a twin turbo kit on ebay for $1500 dont know alot about it.
ferr1s
Naptown
Sts turbo
Hey Guys,
I just picked up an '04 4.8 w/ 32,*** miles 2 weeks ago. Small motor, but the right miles. Anyway, never owned a chevy before, but a deer on the last day of deer season totalled my other vehicle and pushed me to get a new-to-me SUV. The Tahoe seems to be the right choice and I've been really happy with it. I too have been looking for a good/inexpensive system to perk her up a bit. I've found various possibilities, but one that has caught my eye for ease of installation and efficiency is by a company called STS ( Squires Turbo Systems) It appears to be a relatively easy install for the shade tree mechanic. Price isn't great, but it's average from what I can tell. It keeps underhood temps down since the Turbo sits under the vehicle. It also cools the intake charge since the intake pipe also runs under the vehicle to the intake. I also like the fact that even driving it hard, it likely wouldn't have to be cooled for 5-10 minutes before shut down. (as much fun as installing an idle control system is =-) That's about all I know about it. There are some vid's on the net of Tahoes & Silverados running it. It appears to be incredible! I haven't read any evidence about the drawbacks of this particular system other than just trash talk/opinions of some guys who didn't provide any real factual proof against it. I've had a turbocharged vehicle and this appears to remove the drawbacks of that car.
I'd be open to any other opinions of those guys who have systems or have a knowledge of comparable or better systems at a reasonable price that installs as easily.
- Buehler
Volant1
Volant guy
Upland, CA
Ive ran STS on a couple of things here, installs can be easy but you do need to have some know how, most of the ls guys stick to super chargers but STS does make the best kit now there was another company called W2W but I think there gone now, They flipped the passanger side header and mounted the turbo to it
Spooner
Austin, Tx
If you can find one the best would prolly be the Wheel 2 Wheel kit. It uses the stock manifolds by inverting them, and everyone knows the most expensive part of a turbo kit is the manifolds. I dont think W2W is in business anymore but if you can find one, I would go with that.
slocaddy
sarasota fl
i dont know its ok to suggest another site but ls1truck.com is a wealth of knowldge as far as turbo trucks go .
Max
Mile High
Denver
KBracing and Trick both make good kits for front mount systems. Check out www.performancetrucks.net for more info, there are quite a few people running all types of induction on these trucks over there.
rich5368
Cheyenne, WY
These motors from what I read on other sites from guys putting them in older camaros are boost monsters. The bottom end is rock solid and the stock compression ratio makes it perfect for boosting. I would say all stock bottom end with a tune you could probably get away with 9-10lbs of boost if not more with no problems. If I'm wrong please let me know.
smurphy80
does anyone roughly know the cost of an STS kit? I went to their website, but dont feel like having a Rep contact me yet.
Max
Mile High
Denver
$2500 - $4500 depending on new, used, and the associated components.
MOBmentality
Has a $25,000 Punch
I found out that many people are using the super chargers but i found turbo chargers to be a better one. As far as I know, super chargers and turbo chargers are just similar. They are both forced induction systems and that their difference are in its power supply. Turbocharger gets its power from the exhaust stream whereas supercharger has a belt that connects directly to the engine.
hence, i would suggest a turbocharger kit for your turbo setup. :)
There are about 17 billion other differences.. the main one being powerband... a turbo makes almost ZERO horsepower at low rps.. and has to spool up to get any boost.. a supercharger has a parallel powerband because it is belt drive and provides SOME amount of power the entire time the engine is spinning.. from top to bottom
They both have benefits to them and they both have bane, if you want to LAUNCH and you wanna be torquey and be a more efficient towing vehicle AS WELL AS be a hell of alot faster.. then supercharger is the answer.. for a more highway and power from a roll kinda feel.. turbos.
briannorris
