bagged truck with out with out rear sway bar?
mikeyboy
freeport new york
i was reading up on some old threads and saw that on some bagged truck people dont run rear sway bars. i was going to have a project for tomaro of getting smaller sway bar links but now i dont no if i should. now im in a lil jiffy sway bars or no sway bars on a bagged truck and if so what typ of sway bar links. my problem is the truck hops all over the road
Grocery Getter
A guy with a truck.
Phoenix, Az
You'd have to run a four link or watts link to delete the sway bar...... as far as I know. I could be mistaken though but it would be real sketch to run the stock set up w/o sway.
TJ1987
Santa ana CA
My 01 tahoe is bagged and shocked on all 4 corners.... i have no sway bars....still rides firm.....but i do have my panhard bar......that's crucial.
Grocery Getter
A guy with a truck.
Phoenix, Az
im not running a sway bar, it drives fine..but still have my panhard unfortunately..
Can I ask why you would do a sway delete? It won't make it any lower and can only help with handling.......right? Am I missing something? If I am let me know...... I want to do what the cool kids are doing :mexsmoke:
fatnlowtahoe504
New Orleans, LA / Hattiesburg, MS
when you lower a vehicle 5 or more inches you are supposed to get shorter links for the sway bar but i decided just to take it off so i can get more travel with the air ride and go lower, thats what i keep seeing when seeing different air ride instructions but if i remember correctly, i ran into a problem with it when i was doing the rear part of the air ride so i just took it off...
Grocery Getter
A guy with a truck.
Phoenix, Az
Gotch'a...... I have the shorter links and relocated my sway bracket and bar to clear the pan hard..... I will have an adjustable pan hard in a few weeks too...... I also don't have auto ride, thank god, it seems like a real ***** for those who want to roll low......
fatnlowtahoe504
yea i think thats what it was, the pan-hard would hit it, thats why i took it off, i didnt feel like doing the shorter links and all that, i might end up finding some shorter links in the future just to give the truck stiffer on turns
SQNALI
Fort Collins, CO
Id say that the only reason to remove the sway bar is if you wanna go lower and cant because its hitting something. Id rather fix the hitting/rubbing issue of components than remove them. Seems like the only time not having a sway bar would be beneficial is if you were hittin switches side to side.
fatnlowtahoe504
which i plan on doing......but i really dont have that much sway after taking it off, it will only really work if your running bags, but when i took it off and drove with it right before i put bags on it i was swaying like crazy....
airbagd
I've been running mine without a sway bar for almost a year with no problems. I think the key is to make sure you have individual valves for each corner of the truck.
SQNALI
Fort Collins, CO
I maintained the rear sway bar by using rear sway bar links from a 2008 Jeep Grand Cherokee SRT8. I also cut and relocated/welded the rear sway bar mounts on the frame.
Perhaps here in Colorado I find myself on the highway rather often doing 80mph. I-25 has construction down the majority of the highway between Fort Collins and Denver making it imperative to retain the sway bar.
D Rollins
