Under body paint?
raptorforme93
Tampa, Fl
I want to paint my frame on my 96 2 door Tahoe just to keep it nice through the years. How many people have done this to their Tahoe? (2 door or 4 door) How long did it take you and about how much to do it? What kind of paint should I use? Thank you!
mikeyboy
freeport new york
use 3m under coat it dosent take to long i just did it to my f350 presher wash the frame degrees it and use under coat
drowndindreams
Unknown
I just sanded mine down and put a few coats of high heat gloss black enamel. I did all the fender wells, the frame, and the rear drums. I haven't had a problem and it's been quite well over a year.
the big blue bus
richmond, va
i just sanded mine down and sprayed it with black paint. i did it cuz i just installed my body lift. it looks a ton better painted black
96ProCompTahoe
IN
Wires Brush Frame
Wash with soap and water
i used a good coat of rustoleum rusty metal primer followed by 2 good coats of the rustoleum semi gloss black metal paint. been on there almost 2 years and only have noticed a couple little chips.
raptorforme93
raptorforme93
Tampa, Fl
Im going to get the 3m underbody paint and use a wire brush. I wasnt sure who made the best underbody paint. I think that it will deffinitally look a lot better when its all painted black and will preserve the frame for years. Pics of it already done would be awsome!
drowndindreams
Unknown
ill try to get some for you tomorrow
the big blue bus
richmond, va
mines nothing special to look at but i like it alot more after painting...
first ones are before. u can see the rusty frame. the afters are kinda dark ill have to get better ones. but i painted the control arms too and leave springs and stuff out back as well. still need to make my gap guards...
raptorforme93
raptorforme93
Tampa, Fl
Yea it looks much better when you cant see the rusty frame which is mainly why I want to do it. It just looks a lot cleaner
AdrienR
