LED Tails / Strobes?
Z-56 Hoe
What do I do????
Houston
Hey Does anyone know or has anyone put the 90Watt strobes in the LED Tail lights? I want to get a set but I am a first responder and so I still need my strobes in my Tails. To be legel I need them to emit red to the rear tho at least one pair I was looking and it looks like I can put a set in the reverse light spot to the side on the back up bulbs but, is there a spot too drill and mount the strobe tubes in the red part of the tail lights?
nytahoe
"Tha Butcha"
new york
i had white in the reverse light s the 90 watts fringgg bright that was in my nbs.
KrautBurner
Bremerton, Wa
it's actually illegal to modify any DOT approved light fixture
(even for law enforcement)
FPS was siting local law enforcement agencies for having strobes installed in the dot lighting of there cruisers a few years back (in DC)
Z-56 Hoe
Z-56 Hoe
What do I do????
Houston
I would get out and beat someone's ass if they tried that bs there is supposed to be a common courtesy there
AquinoSteven
Key and Spacer Guru
Clinton, NJ
yeah thats just dumb. I look at all the police tahoes here and they have their strobes right in the factory lights. You could put it in the reverse light and use a red cover?
Huck
Whut Thee Huck?!
San Diego
I would love to see a cop get pulled over by another cop.
Z-56 Hoe
Z-56 Hoe
What do I do????
Houston
it happens all the time but not a marked unit pulling over another marked unit. thats just bad Joo Joo.
jomulk56
Resident Lurker
IN
They make red LED stobe kits you could put in the reverse light area. I haven't seen the inside of an LED tail to know if you could put them in the red part.
Z-56 Hoe
Z-56 Hoe
What do I do????
Houston
I know I can also order red strobe tubes but those just arent as bright. I already have the strobe tubes in my stock tails. Thats why there not tinted tho.
KrautBurner
Bremerton, Wa
what about throwing something like this inside your rear windows
http://www.autodirectsave.com/86655-Bumper-Window-Strobe-6-LED-P36C33.aspx
maybe even mount them above the rear bumper, below the hatch (same place you'd mount the "line of fire" brake light
Z-56 Hoe
Z-56 Hoe
What do I do????
Houston
I have a full bar in the front and back windows. I need something lower too
slov1230
Atlanta,Ga
try whelen vertex RED LED strobes in the reverse lights...thats what i have and they definitly do the job
VonZipper748
I have strobe tubes in the tail and reverse of my obs tahoe the reverse one was a little tight but fit. Also a company called feniex industeries developed a 3 mode dual color hideaway led light. So if you wanted you could get red/white and replace your reverse lights with them and not cut anything but you will have to tap into your reverse light wiring
Z-56 Hoe
Z-56 Hoe
What do I do????
Houston
Lol talk about a post from the past. Yeah I have the new Feniex cannon 360's.
HeavyHoe03
