Color Matched My Grill Shell
Oklahoma
Finally got around to color matching my grill shell today. Next is bempers!
killer20072001
Oklahoma
Why thank you sir.
I think im gonna have to get a differant clear I dont like the one that is on there. Its the duplicolor perfect match, and it didnt go on looking very wet. The one can wasnt nearly enough. Those cans are a rip off. $6 for 2 1/2 coats.
Z-56 Hoe
What do I do????
Houston
Good Mod I like it too, I did Mine last year. Looks so much cleaner~
Devious02
Denver, Colorado
You did this with spray paint?? I thought I had to take it someone to get it done. Is the color exact as factory looks like it in pic.. Looks good. Do you have a write up.
mrtrill
ATL
wow...what a risk taker!..lol
but it looks good from the pics u have shown.
killer20072001
Oklahoma
Yep. I used duplicolor exact match. The color is dead on I just need a better clear. Those were the only pics I took because I was pressed for time, but it wasnt to hard. I ruffed it up with some 320 grit wet or dry sand paper. Cleaned it real good with dish soap and a rag. Sprayed 3 coats of adhesion promoter. Then a light coat of self etching primer. Two more heavy coats of primer. Sanded with 600 grit. Washed cleaned again. Hit it with a tack cloth after it dryed. Shot 3 more coats of primer. Sanded again with 600 then finished with 1500 for a smooth surface. Cleaned again. Tack cloth again. Used two cans of the duplicolor exact match paint. Dont remember how many coats it was. Then finished it off with a can of clear. Im not to happy with how dull the clear turned out. Im gonna wait 48 hours then hit it with some polishing compound and wax see how it ends up then, but ill probably end up re spraying with some better clear.
fire730
Louisiana
How about a 3/4 shot from a distance? I have a white Yukon and I have an newer style W/T grill that I can paint but I am on the fence about painting it white and having the chrome bumper.
Good work
fire730
Louisiana
Exactly what I wanted to see. Thanks. :Handshake:
I just didn't want to paint the grill before I got a paintable bumper.
It does look good though.
gfunkfb09
I plan on doing this, I just have a few questions.
When you sand it, do you sand all of the "fake" chrome off of the grille? Part of my chrome has already began to come off, a piece of it did from my stupid power washer. Its right below the passenger side headlight and it really pisses me off.
And my Yukon is Summit White, I assume duplicolor has a match for this color I can get at any auto parts store?
Thanks.
jomulk56
Resident Lurker
IN
Thanks.
If you can get all the chrome off the paint will stick better. If you can't get it all off just get the peeling sections off. Either way use an adhesion promoter since it is plastic. Your auto parts store should have the paint, or at least a book with your paint code and their color that matches.
GM Driver2
Colorado
Ill be doing this again this week...did it a month and half ago, and the chipping has begun. Not a fan of that. So i will be painting that, as well the chrome again until i can get a paintable one.
gfunkfb09
Thanks, I really wanna try this!
Yang1815
I like the matching grill but maybe the GMC doesn't have to match. That's just me though.
Drewphil
