87 or 91 octane gas
Nagloc68
I searched the forum and couldn’t find a related thread. If there is one, feel free to point me to it.
Original Owner of a 2013 Yukon xl Denali with 191k. Original car, well maintained but stock, original tune so maintains the V8/V4 feature. We have used 87 octane its whole life. Have been reading a bit and have interpreted some comments suggest 91 octane is preferred. But it has always been about $1 more a gallon which is why we used 87. Most of its gas has been purchased at our local Costco which is top tier. 91 is currently $5.23 at Costco!
Engine drives strong and hasn’t caused any concerns. Much of my miles are highway miles. My question is at 191k miles is there any reason to change the octane of gas I use?
Thanks
donjetman
If you want to extend your range/mpg? run premium. In our Denali (mostly hwy) premium pays for itself.
GM recommends premium with our 07 6.2L L92.
I experimented w/87 and 89 unleaded and gas mileage suffered and I got an occasional "Knock Detected" on the digital info center, not good.
Your vehicle may have lower compression and be tuned from GM for regular? In that case premium would have no effect
Thanks
Many threads and opinions on this topic, and it has been discussed ad nauseum on this Forum. I did a quick search, and surprisingly, I found very little on this topic, just as you experienced. We really need a better search engine on this Forum.
Bottom line, some use 87 octane, but most use 91 octane, as recommended by GM. If you are at 191k miles using 87 octane without any issues or knocking, then I'd say keep on using it.
Thanks
your good, no reason to start paying more now.
if you want a tiny bit more giddy up use e85 if you have it available, you might not feel the difference though
Foggy
KS
It's a high compression engine.. So it requires 91 octane. Just like
it says in manual.
IF you run lower octane, it will knock/detonate... Then Ecm will adjust to
the low octane spark table (of course after some knock-bad- is detected)
It will stay in that low octane table and your gas mileage will suffer.
So it's up to you to justify what it wants - 91 octane
You can risk knock/pre ignition/detonation and worse mpg OR
just put in what it's designed to run
mikez71
I thought that was one of the benefits of the 6.0 over the 6.2, to ability to reliably run regular gas?
Though being at 191k on the 6.2, that sounds pretty reliable...
the 18th letter
Northern New Jersey
Thanks
At 191k with AFM enabled I can’t think of one reasonable argument to change octane at this point. Not one…this is assuming you haven’t rebuilt the motor at any point already since you said ‘original car’.
Foggy
KS
Yup . The 6.0 in the 2500hd has the cast iron block and lower compression
Also NO DOD and a little diff cam profile than the 6.2
So it doesn't need the higher octane
Bill Barnes
Catlett, VA
I read all of the replies on this thread, and agree with most of them. Here in Virginia, we have a convenience chain called Sheetz, and it offers an 88 octane E15 gas that is always about 40 to 50 cents a gallon less than the 87 octane regular E10. The pump handle and selection button are color coded in blue. My 2005 Yukon XL 5.3 FLEX Fuel 4X4 likes it just fine. I have 300K miles on the vehicle, and I've been using the 88 octane E15 for 100K with no problems, and maybe a tiny bit better mileage, maybe 5%.
donjetman
Ethanol has less energy (BTUs) per gallon than gasoline so mileage/range suffers, but it cheaper.
I've run mixtures of as much as 30% ethanol and no issue(s).
Marky Dissod
L92/L9H/L94 are NOT high (static) compression engines - L76s (not truck L76, car L76s) and L77s also have 10.4:1 static compression, and run 87 just fine.
NOT a recommendation, but you can GET AWAY with it - that's what the low octane table is for. You SHOULD use 91. I don't talk to adults like they're kids,
all y'all apparently forgot the original '07 L92's power rating of 380 horses on 87 octane:
I'll NEVER recommend 87 in an L92/L9H/L94, neither does GM, but GM was never against 87 either.
91 octane is worth at least 20 horsepower, according to GM; see pic above.
GM OE tuneS are the major variable here - I've not yet compared '07 L92 calibrations to later ones. Has anyone?
LSCALADE
2013 is a flex fuel L94 so mix 87 with E84 and you get something around 93-94 octane.
If you have a way to log knock retard events, you will see that the engine is constantly pulling 4-6deg of timing at every event. You may not feel it or hear it but its there and its wasting fuel and reducing power. When I mix E85 in the mix so 2gal 87 to 1 gal E85 knock disappears entirely; that tell you something. So a mix of E85 or 91/93 is the sweet spot if you want this thing to last.
These engines are high compression and with mileage they do accumulate carbon deposits on the piston tops, which with heat start to glow and further cause detonation events. I have a Cammed 6.2 that absolutely hates seeing anything less than 93 in the tank but its tuned and non flex capable so it has to run 93. Fun truck but I hate its gas mileage.
Marky Dissod
@LSCALADE, asking out of genuine curiosity.
Ever had the chance to compare the High & Low octane Spark Timing tables of an '07 L92 to an L94?
'cause it's not like GM couldn't write 87 octane tables for an L92 if they wanted to -
it's exactly what they did for the L76 & L77, which are 10.4:1, yet only require 87 octane.
Mild correction: L92/L9H/L94 are 10.5:1
Again, note that in '07, L92s were cited @ 380 horse on 87 octane by GM, not by a troll.
At sea level, 1/3rd of E85 (even if it's E51!) to 2/3rds of 87 octane petrol yields at least 91 octane.
At very high altitudes 1/2 of E85 (again, even if it's E51) to 1/2 of 85 octane petrol yields at least 91.
N
Nagloc68
I appreciate the clarification of the GM engine types and octanes. We ran 87 because it was allowed. I recall clearly at time of purchase (December 2012) that it was ok to run 87. I didn’t want a car that required 91. I also recall 91 was recommended but 87 was approved. I have had no problems. Even today the engine is beautiful, accelerating this huge car forever… and it’s still comfortable to drive.
Marky Dissod
Only by GM, we frown upon it, :confused: :mad: , unless you drive daisy.
I have had no problems. Even today the engine is beautiful, accelerating this huge car forever ... and it’s still comfortable to drive.
So long as you do not make the engine work or play HARD, 87 should be ok, just remember 91 would of course be much better.
Depending on the price of 89 & 91 vs 87 where you tend to drive, you may want to compare those prices carefully.
(Once the price of E85 dropped in NYC, for example, I stopped using 87 entirely, and the engine likes it too, especially when I floor it.
87 used to ping a wee lil bit - 2° retard over 4800RpM - but no ping with E85.)
Point is, if the math works for you, 91 or E85 would be better in the long run.
N
Nagloc68
We haven't towed or anything else heavy - mostly hauling the four kids. Now its mine I mostly highway driving. Chicago suburbs area, Premium is about $1+ per gallon over 87. I fill up at Costco and save about 25-35c over local stations (used to be 50c). Costco doesn't have E85 at my location. I will check the price of E85 and maybe experiment a little. Thanks again.
vcode
Premium is 25-30% more than regular here. Never gonna pay for that here.
Marky Dissod
The price premium of 'premium' is different everywhere; everyone has to do their own maths to see if it works for them, and results DEFINITELY vary.
CrackerJack135
