jaxscuby
differential service for front & rear. replaced serpentine belt.
oh yeah, a k&N catch can.
Seem legit. Thanks for your input, I really appreciate it.I can’t tell you what he’s charge, but if it was me I’d probably charge you close to that $360 for the one but then do the two of them for like $550 or something because the prep for both can happen at the same time and the use of materials won’t be that much more![]()
Okay, so when I install it give it a good yank to make sure it's not coming off. Check! Thank you!Mine blew off with the wind most likely due to the twist-lock fasteners being loose — I had no idea how that thing was fastened on as I never messed with it or even knew I had a trailer hitch there. Never had a problem with the second one that I installed and was 100% sure that the fasteners were properly engaged.
How was this mileage determined? By your on board GM server or your manual calculations?Just wrapped up a 3800 mile road trip to Northern Idaho and back. Tahoe ran flawlessly.
I set the cruise control around 80 the whole way, rather than the 85 I did last summer.
Was impressed with the fuel economy I got 20.6mpg on the way up 19.7 on the way back.
Not bad for being weighed down with all our camping gear filling the back to the ceiling!
Manual calculations.How was this mileage determined? By your on board GM server or your manual calculations?
I did the upgrade as well. Pretty straight forward install, but performance only improved slightly. Not sure if it was worth the cost or not ($110)Just completed the wireless charger upgrade to the second generation. I scored a new condition 13521066 gen 2 charger off of eBay for $60 and it came with the plug. The Gen 1 and Gen 2 use the same color wiring scheme but the plugs (and individual female terminals) are different. If you try this mod, try to get a Gen 2 with an adapter pigtail or at least with a blunt-cut pigtail so you can match up and cut & crimp your truck’s existing harness. The bottom cover just pops off with a panel removal tool and the four screws that hold the charger onto the lid are T15 torx. Charger works great now! If only there was a way to get wireless Apple CarPlay without using some sort of off-brand CHICOM adapter. I’m very suspicious of using no-name CHICOM products that physically plug into or use wireless data with my mobile phone. Anyone here know of a reputable brand that has a wireless CarPlay adapter?
View attachment 488969View attachment 488970
Those look really nice. I tried to locate your build thread, but couldn't find it. Guess I'll need to improve my detective skillsFinished a custom set of headlights with bi-led projectors, and blacked out the front end. More details on the headlights in my build thread if you're curious
May need to realign the headlights after some testing, they are 3" lower than the alignment point at 20ft but visually look too high
Those look really nice. I tried to locate your build thread, but could not find it.
How are the powerstops on the tahoe? I have a set in my Subaru and love them, wondering if they work just as well with the extra weightFog lights and PowerStop Extreme pads and rotors installed this week. Also got a bath today.
I don't know which ones he used but the 2010 police issue ones one's work great, yes they fit rockauto only markets them for 2009/2010 police tahoe'sHow are the powerstops on the tahoe? I have a set in my Subaru and love them, wondering if they work just as well with the extra weight
Hence…. PowerStopThese are the ones I got. I haven't done any actual A/B testing, but pedal feel is much better and they give me much more confidence in the stopping power over the OEM style pads and rotors I had previously.
