2022 5.3 tahoe going into limp mode
MoundMedic7
Okay I need some help from the pro's on here. Just bout a 22 5.3 Tahoe about 2 months ago with extended warranty. 72,000 miles. About a month in, I was driving when traction control, abs, and other sensors started going off and it went into limp mode. Dealership was closed so I pulled into AutoZone. I don't remember the code number but it was related to the fuel pressure system. The next morning, I drove it to the dealership. It has exited limp mode and drove fine but the check engine light was still on. The dealership drove it 100 miles and could not recreate the problem. Got it back with no solution. Well it happened again Sunday (my luck). It has again reset to driving fine. I don't want to pay the 200 dollar diagnostic fee for the same results if it is just a simple sensor issue I can replace. Has anyone dealt with this??
2024 White Tahoe
When you took the vehicle to the dealer and the check-engine light was still on, they should have retrieved a stored code and began repairs.
You said you have an extended warranty (service plan) - do you have a $200 deductible for the plan?
If you paid the deductible the first visit - you should not have to pay again as the problem was not repaired and has recurred.
M
MoundMedic7
The dealership said the code was not "active" but it was showing in the history. The code in itself was broad but they checked the fuel pressure and said it was fine. And the first time I was still under a 30 day dealer warranty so they paid it, but this time I am trying to save the extended warranty claims for a more serious issue if it is a simple fix.
GMCnewbee
First, go to another Dealer. It should not be that hard for a decent Tech to figure out these things. A busy Dealership sees a lot and probably knows right away what is up. About a month ago I had the Fuel Control Module go out suddenly on our 2022 Yukon. The local Dealership knew right away what it was, had the Module in stock, and the Tech had just replaced one on his Father's pickup. Called On Star, got towed, got fixed the same day, all under Warranty.
M
MoundMedic7
okay thanks I will try that
a1parrothead
