2021 Yukon AT4 5.3 using oil
dynoray
hello, my daughter has this 21 5.3 Yukon with 60,000 miles. we always change the oil and filter sooner than the oil life because she does alot of around town driving. i noticed lately it was down 2 quarts. Anyone run into this issue? ive heard about issues with these engines,but no oil burning. thanks,Ray
D
dynoray
first time this has happened, the low oil light came on. never seen before. in the past oil has been always full and no leaks
2024 White Tahoe
Do you do your own engine oil and filter changes? You said “we always change the oil and filter …”.
Is it possible an incorrect amount of oil was put in the engine with the last oil change?
The owner’s manual for my 2024 Tahoe with the 5.3L engine states to wait at least two hours after engine shut-off before checking the engine oil.
Did you wait to check the oil after engine shutdown?
My question to you is how did you know that the oil was down 2 quarts? Did you measure the amount of old oil that came out of the oil pan when you drained it? The maximum oil drop that you can see on the oil dip stick is down 1 quart, if the measured oil level is down to the 4th set of holes on the dipstick.
blanchard7684
Senior Member
Verify the condition first. Top off oil. Take a picture of the dipstick. Drive the same number of miles (approximate). Evaluate.
You may have had lower oil level to start with.
GMT800 2005 Tahoe Z71
Navy Supporting Member
I still don't see the answer to how often you check her oil? Problems can start at any time. I check mine every other day. At least you should check once a week.
Plus, the oil may not have been filled properly.
jfoj
Did not mention where my the vehicle is located. Between low temps and possible high pressure fuel pump problems, the oil could be fuel contaminated, which would cause quicker oil consumption. Oil should be checked every fill up on these vehicles, that would typically be around every 300-500 miles depending on how vehicle is driven. Also smell the towel you wipe the dipstick with to smell for fuel. The low oil light typically comes on when the oil level is 2 qt's low.
Also consider a different oil brand, sometimes the same weight oil from a different brand will be consumed less. This is a cheap and easy test the next oil change.
Vladimir2306
My 6.2 doesn’t use any oil? Last oil change was 5000 miles ago. Level didn’t move.
If you drive calmly, then the oil will not be consumed. I drive fast and actively, so I did not use oil for the first 4000 km, and then 0.5 liters every 1000 km.
AZPatriot1963
