Replacing steering box?? Or what ?
mountie
mountie
I sure hope the ball joints were inspected. Here is what typically happens. Ball joints wear excessively on a high mileage vehicle which cause tires to constantly be trying to move toe in and toe out just slightly up to alot depending on how bad the ball joints are. All this side to side motion causes the output shaft of the steering gearbox to wiggle side to side and ruin the seal at that output shaft and not to mention the gearbox. Its hard to find until you know to look for it. Have to get someone to move steering wheel just slightly to the right and left back and forth and watch that output shaft.
Good info……. My front steering & suspension / balljoints etc. is new, installed by a VERY good custom truck shop along with Hellwig sway bars, about 6 months ago, along with them doing a front/rear alignment …. Then had my tires a ‘road-force’ balancing.
>> Just got back, getting the alignment….
My ’05 truck rides like an S Class Mercedes at speed.
mountie
mountie
My whole front suspension & tierods, etc are new. My new steering box was hand built w/ all new parts including , they did the seal fixes that the GM version was known to fail.
HudsonRoyce
I once had seepage on my 99 Silverado rack and pinion, so I added some Lucas stop leak. This was like in 2011 and I didn't know better.
A few days later making a turn on a shopping center from the main street, the steering got locked after turning left. I couldn't recenter the steering wheel. It was crazy! I sat there for about 15 minutes, shutting and restarting the engine, until I finally got it working again. Luckily I wasn't far from home, and went straight back. I immediately called my mechanic and he told me to drive it over there. Leaving my home street, it happened again, but it wasn't as bad. In both cases, there was no traffic, but I could have had an accident.
The only thing I was able to conclude is the very high viscosity of the stop leak somehow caused some hydraulic line to temporarily clog. IDK. That was my original rack and my mechanic replaced it and never had that problem again.
This may not apply to the gearbox setup though (probably exclusive to rack and pinion systems), but just thought I would share my experience. That was my first and last time using stop leak. Lol⠀⠀⠀
Yeah that’s exactly why I stay away from stop leak. It might help short term, but the risk of clogging something in the system just isn’t worth it, especially with steering.
Roilux
Senior Member
Firefighter Supporting Member
Burbank, CA
Steering box is not a reman……. This is their test result sheet.
But not quite finished yet….. The pitman arm is limited how it attaches to the steering box shaft….. I am now researching how to ‘spot’ the steering wheel back to center….. I may just get another front end alignment to center it?
I installed my P&E 3009 box yesterday and now have nearly the same steering wheel position as your photo. :cheers:
The new box install revealed the upper steering shaft I replaced about 3k miles ago has effectively failed. The Ultra-Power steering shaft purchased from Rock Auto is hot garbage giving steering wheel play just inside of 11 o'clock to 1 o'clock. After removing the steering wheel dust boot from the firewall I can see play between the upper tube and shaft that slides into it. Grrrrrr........
A new shaft is due to arrive Friday. I'm looking forward to a Mountie-esqe driving experience once I get it buttoned up and the steering wheel centered.
mountie
mountie
If you tend to drive a bit aggressively, ….. You’re gonna love it !!
Roilux
Senior Member
Burbank, CA
The upper shaft replacement revealed play inside the steering column, notably the steering column shaft that connects to the steering wheel. With the boot removed from the firewall a small amount of play was noted. I started a separate thread about that adventure and its pleasing outcome.
Pertaining to this thread, the P&E 3009 steering box is indeed a quality unit that I'll recommend whenever the question arises.
Thank you for suggesting it.
mountie
mountie
Your welcome ! This forum is full of good information.
CRN_25
