Air suspension option
Jus Cruisin
Metro Detroit
I had air suspension on my 2019 Ram Limited pickup and was really happy with it. It had an entry feature that would lower the truck and make it easier for my mil to get in. Does the Yukon system do the same?
genestoy
Arizona
Yes, My 2026 Yukon AT4 does the same, you set it in the Infotainment, turn off the vehicle and do not open the doors and it lowers, has a notification that it is lowering and a little green car displays on the DIC. If you open the door it stops lowering, then after you close the door it continues to lower.
olyelr
Elk Rapids, MI
Yea gm’s version is pretty much the same as rams…100% air, raises for offroad use, lowers for easy entry etc.
And both come with complexity and a slew of possible issues haaaa.
When they work properly they are great. But there is a reason why there are kits to replace the air suspension with typical coils/struts haaaa.
Rams are notorious for having issues in cold climates. Havnt read about as many issues with gm’s, but have still read of a slew of them…brand new vehicles sitting in the back of lots on their bumpstops.
AllyNJ
