replacement dash ?
07burban88
so, I'm in need of a whole new dash for my 07 burb as its busted around the radio and above the cluster. my issue is i don't want to spend 1500 from GM and yes that's using my shop for the wholesale price. is there an aftermarket option that's slightly cheaper?
you can get a dashcap for cheaper but beware it covers the access to remove the cluster if that ever needs to be serviced, you can of course pull the cap off to do it but they are glued on when installed.
if you poke around the site there is one guy I think in texas that can get some re-pops from mexico that are a close fit.
07burban88
yeah, I have a cloth dash cover but the damage around the radio is no longer holding my radio in
mikez71
Some have replaced with factory dashboards.
There is a fiberglass dash, which might save you around $500 compared to a factory one, but needs paint and fitting.
Once you spend all that money for a new dash, you'll block it from your memory and forget all about it..
LsHart
Senior Member
Any yards close to u?
07burban88
i have a few yards around me but if i remember there all the same condition. be cool if a gmt900 Silverado dash would fit. they look better
mikez71
Would be cool..
Center console might not line up..
Would need the passenger airbag and HVAC ducting too.
Not dual zone, so might need some custom ducting.
kbuskill
NE. FL.
Would be cool..
Mark @Rocket Man swapped the dash in his Silverado for the LTZ dash out of an SUV in his bagged and bodied Silvy. The info is probably in his build thread on here.
Conedaddy
