2025 Tahoe 24" Aftermarket Wheels
scarughi
I took measurements again last night. Its right at 1.5" of drop if you set the links to what are on the instructions. Of course I went from stock wheels and tires to larger wheels and tires so depending on your setup it could be a bigger difference. I rounded everything to the nearest .25" so they could be slightly different and I measured at the center of the wheel from the floor to the bottom of the wheel arch. Theres about 4" of total travel from the entry/exit setting to the highest 4L setting.
Stock Height-Normal Setting. Lowering Links-Normal Setting
Front Right-36.75" Front Right-35.25"
Front Left-37.25" Front Left-35.75"
Rear Right-37.5" Rear Right-36"
Rear Left-37.75" Rear Left-36.25"
Stock Height-Entry/Exit. Lowering Links-Entry/Exit
Front Right-35" Front Right-33.5"
Front Left-35.25" Front Left-33.75"
Rear Right-36.25" Rear Right-34.75"
Rear Left-36.5" Rear Left-35"
Are your pics shown in the Entry/Exit mode with lowering links? Do you have any in the driving mode with the Lowering links. Planning on installing these. Your Tahoe looks great!
kikeap
