2025 Tahoe 24" Aftermarket Wheels
tightchevelle69
Florida
Bought a 2025 Tahoe RST with 22" wheels. Looking to upgrade to 24" Wheels. The factory 24's come in a 9.5" width, the aftermarket ones come in 10". What backspacing and offset should I be looking for? The ones im looking at are 24x10 with 6.44 backspacing and +24 offset. Pic of truck and pic of the wheels im looking at attached.
Dag300c
Just got a 2025 tahoe high country im going 26x10 and ive had people recomend +15 for flush fitment and others recomend +20 to stay in just a little bit inside fenders. I dnt know what to go with but i see alot of people prefer flush fitment over inside the fenders. I Got from here till spring so i can make up my mind. Let me know if you end up getting anything
tightchevelle69
tightchevelle69
Florida
I did order some 24's with all terrain tires. They were supposed to be delivered tomorrow but still havent shipped. Hopefully they will be here in the next week or so and I can shoot you a couple pictures with the specs of the wheels. I also ordered lowering links (ours has the adaptive air suspension) to drop it down 1-2".
KMeloney
You already ordered the wheels but don't want to tell Dag the specs? That's curious... Just want to make sure that they fit first?
I hope you post pics here. Looking forward to seeing them!
tightchevelle69
tightchevelle69
Florida
I can post the specs but without pictures to go along with it I dont think it would really help.
Wheels:
Brand: Factory Reproductions
Model: FR98
Model Other: Escalade 12 Spoke Replica Wheels
Part Number: 98410316502
Wheel Finish: Gloss Black
Backspacing: 6.72
Bolt Pattern: 6x5.5
Offset: 31mm
Wheel Diameter: 24
Wheel Width: 10
Hub Bore: 78.10
Load Rating: 2200
Wheel Exposed Lugs: Yes
Wheel Material: Alloy
Wheel Structure: One Piece
Wheel Spoke Number: 6
Tires:
Brand: Venom Power
Model: Terra Hunter X/T
Inventory Number: CVPXT04
Aspect Ratio: 40
Inflated Diameter: 32.98
Inflated Width: 11.22
Load Index: 112
Section Width: 285
Service Description: 112H
Sidewall: Black Side Wall
Speed Index: H
Temperature: B
Tire Rim Diameter: 24
Tire Type: Hybrid AT/MT
Tire Type2: All Terrain
Traction: A
Tread Wear: 500
UTQG: 500AB
Weight: 44.16 lbs
nomech
@KMeloney @Dag300c I finally got the wheels and tires installed a couple weeks ago but this was the first time ive been back on the forum.View attachment 447314View attachment 447315View attachment 447316View attachment 447317
That drop looks great along with those rims.
The color looks to be dark ash, I can't decide between dark ash or black. I like dark gray colored vehicles, but it also looks like dark ash has a dark purple color based on the way the sun hits the paint.
tightchevelle69
tightchevelle69
Florida
It is dark ash metallic. It does sometimes have a purple/blue hue depending on lighting but it does look black at night. It is a really nice color and IMO the metallic helps hide some dirt and microscratches compared to the standard black.
nomech
Does your RST have air suspension?
What did you use to lower the vehicle?
Any tire rub with the wheel/tire combo you have?
I put factory size tires on my factory wheels and I have a little tire rub if I turn the wheel hard one way or another and I typically only do that if I'm in a tight spot and usually I'm going very slow (on the brakes, most of the time). I posted on here and people said that the tires I bought just have a bit more rubber than the factory brand. Anyway, I was just curious about your setup since you have wider wheels, but the offset also plays a factor into that, as well.
tightchevelle69
tightchevelle69
Florida
It does have the adaptive air suspension. I used lowering links from edgymods.com. They are extremely easy to install!
I have not noticed any rubbing. I went with the same size tires that come on the 24" wheels from the factory. But since the wheels are slightly wider the tires fit a little different than the would on narrower wheels. I wouldnt worry about the slight rubbing you get at full lock. Like you said, it doesnt happen all the time and its never going to be at highway speeds when it does occur.....if it is, you most likely have a bigger problem on your hand!
nomech
I don't know much about tires, I never realized that one tire size could fit slightly wider tires, that's interesting.
tightchevelle69
tightchevelle69
Florida
People do all kinds of crazy stuff with tires, not always safe, but they do it. Look up tire stretching!! You can also put a much wider tire on a narrower wheel
nomech
I have another question, I just found the part number for the tahoe and it says they are the same size as the stock component but change the voltage sent to the computer to allow/control the 2.5 inch drop. I get that part, it is also nice that the OEM parts can be swapped back at any time.
In the pic you sent, is that the car stance in 'normal' ride height mode? If so, can you take a pic of it lowered to the entry/exit setting?
I wish you could set the vehicle to entry/exit and just drive in that mode at all times. Obviously GM doesn't want you doing that which is why the aftermarket parts exist.
Thanks.
tightchevelle69
tightchevelle69
Florida
Thanks.
So, the end fittings are the same size but the length of the rods is adjustable. All these do is adjust where the air ride sensor arm is in relation to the control arm. So basically it is tricking the truck into thinking it is at normal height even though it is lower.
The pic shows it in entry/exit setting. Normal ride height is a little lower than what entry/exit mode is stock, I think. I took measurements before lowering it but still havent taken the measurements after. Ill try to remember to take the measurements when I get home this evening.
I can tell you that if you set the rod lengths to approximately what he has listed (165mm and 108mm), most times you will have to trick the truck into entry/exit mode. If you pull up, stop and put it in park, it will begin lowering but most of the time before it gets to the correct height it flashes a message saying object detected under the vehicle and will begin raising back up to normal setting. The only trick I have found to get it into entry/exit mode is to select entry/exit mode on the switch about 10 seconds before getting to the final parking spot and pulling in very slowly. You definitely do not want to drive it at the entry/exit mode setting because you will be riding on bumpstops and its very bouncy.
CMoore711
The wheels do look good. The GMT900 and K2XX platform required some higher offsets on both Factory and aftermarket rims and clearly the T1XX '21+ platform are wider and should have a lower offset to avoid the inset/tucked look like you have going on. It's not a good or bad thing, I think maybe more of a preference thing and potentially some impact on the larger OEM 4 piston front brake calipers.
Check @DaveLaz post #81 in this thread here: https://www.tahoeyukonforum.com/threads/lowered-21-t1xx-post-em-up.133295/page-9
tightchevelle69
tightchevelle69
Florida
I prefer the look of wheels tucked a little vs flush. I would definitely need spacers if it had the larger brembo brakes but these fit fine over the regular calipers.
tightchevelle69
tightchevelle69
Florida
Thanks.
I took measurements again last night. Its right at 1.5" of drop if you set the links to what are on the instructions. Of course I went from stock wheels and tires to larger wheels and tires so depending on your setup it could be a bigger difference. I rounded everything to the nearest .25" so they could be slightly different and I measured at the center of the wheel from the floor to the bottom of the wheel arch. Theres about 4" of total travel from the entry/exit setting to the highest 4L setting.
Stock Height-Normal Setting. Lowering Links-Normal Setting
Front Right-36.75" Front Right-35.25"
Front Left-37.25" Front Left-35.75"
Rear Right-37.5" Rear Right-36"
Rear Left-37.75" Rear Left-36.25"
Stock Height-Entry/Exit. Lowering Links-Entry/Exit
Front Right-35" Front Right-33.5"
Front Left-35.25" Front Left-33.75"
Rear Right-36.25" Rear Right-34.75"
Rear Left-36.5" Rear Left-35"
nomech
@tightchevelle69
Did you do anything when you changed from 22s to 24s, in terms of recalibrating the vehicle sensors? I read another post stating that someone that went with aftermarket wheels (bigger than stock) had poor gas mileage and another person responded saying that the vehicle sensors/etc needed to be recalibrated.
tightchevelle69
tightchevelle69
Florida
@tightchevelle69
I did not. The diameter of the stock tires vs the ones I used on the 24's is only .6% difference. Its so little of a difference that its not really needed.
15TahoeSSV
