Hellacious tahoe
- Joined
- Apr 20, 2026
- Posts
- 16
- Reaction score
- 24
Last fall, I bought this 07 tahoe and as soon as I made it home after a 200 km trek I changed the oil. At that time, I thought the oil was too thin, but dismissed it as overdue oil. After a double flush I poures 5w30 synthetic and a new fram filter. I spent the rest of the fall replacing the shocks and doing body work. There was a code pointing to the evap valve, which I replaced. Winter came and I stored the truck, but ran it at idle every 2 to 3 weeks while in storage. One cold February morning it made strange noises and the low oil pressure warning came up. I waited for the spring to address this, but spring came up and it ran like nothing ever happened. The evap code came back and after visually checking all the hoses, canister ect I dropped the tank and found a fuel pump from a prior generation Tahoe had been rigged in. I replaced the pump with the correct one and the evap code did not return. One day it made similar extrange noises, this time sounded like coming from the oil pump area . I drained the (new) oil and found it very thin with an obvious gas smell. I just dont know how gasoline is coming into the crankcase, since this truck does not have the high pressure pump that is notorious to leak on 2012 and newer models. I dont know what to do next and came into this forum pleading for a little help. In advance, I thank you for reading this long post and remain on standby for your input. Cheers
