2011 Tahoe Intermittent Left Rear Door Ajar MSG and thinks door is open and alarm activates.
opfor2
Riverside County, CA
I get a MSG stating, "Left Rear Door Ajar" and the interior lights stay on when driving and when parked and locked however, the door is secured. The alarm will activate when the vehicle thinks that the door is open. This occurred out of the blue after I got the car washed. Any ideas on where to start looking? BTW the left rear door larch was replaced about six months ago.
mikez71
I would guess the door latch.. Or the light-blue/black wire is broken and grounding out? (seems unlikely)
opfor2
opfor2
I just replaced that door latch about 5 months ago with a Standard DLA822 from Rockauto. I just ordered a replacement GM GENUINE 22862036 from RA for I'm thinking that the switch is defective.
LsHart
Senior Member
Spray a little pb up in there and open and shut the door bout 5 to 8 times.
opfor2
opfor2
I think I'm dealing with water intrusion here for once it dried up it was back to normal took the truck to the car wash and then it went back to acting stupid. I did buy a new OEM GM unit from Rockauto that I just haven't had time to install yet but I'm sure this will fix the issue. The aftermarket door actuator is a "Standard DLA822" purchased from Rockauto.
LsHart
Senior Member
WD40. Water displacement to the 40 perfection!
Towmaster
