Excessive heat
phatz_hatz
lawn guyland
Flushed whole cooling system today, replaced thermostat, thermostat housing, upper and lower hoses, and this “heater valve” with the AC on it seems like it’s not diverting the coolant back into the cooling system and just going into heater core thus making the AC struggle to work cause it’s blowing through the hot heater core. Unsure if it’s related to replacing it, it’s. GPD heater valve right now have it zip tied to so i get AC. Could it be the vacuum motor, or the switch inside the cab
Eman85
!997 Tahoe when my valve leaked I installed it in the garbage can and just ran 2 heater hoses, AC works fine. My PU never had a valve and AC works fine. If you're worried about max AC put a manual valve inline and shut the water in the summer.
phatz_hatz
phatz_hatz
lawn guyland
Been thinking about this or running a vacuum line straight to intake manifold to bypass the control solenoid. The solenoid isn’t getting power from the switch inside the cab, or it works intermittently cause it worked sometimes before that, so it’s not activating the vacuum
phatz_hatz
phatz_hatz
lawn guyland
This is what i came up with after testing the power with the ac on full blast and still wasn’t getting it to power. Ran all new vacuum lines to everything, put a 1/4 valve from back of intake manifold directly to heater valve turn it off for winter and on in summer. Simple fix
AZPatriot1963
