My 2018 Yukon Denali down for Brembos front & rear
MrMonte
My 2018 Yukon Denali has 134K miles on the original brakes and I gave up waiting for them to wear out so she is down for a Brembo upgrade front & rear. I've had the Brembos sitting around for over a year.
Completed the rear today. I used calipers from a Gen6 Camaro SS. Rear pads had 40% life left and rotors show very little wear. After cleaning them they measure .7865" with new being .79" & below .73" is trash so I am reusing the original rear rotors.
Some trimming required to clear the 4 piston Brembo calipers . The 6 piston Brembos with 16.2" rotors for the front need new backing plates so that will be fun & likely tomorrow's project.
Here's before trimming.
Here's after trimming.
Here's the rear complete & front rotor preview.
MrMonte
MrMonte
Installed the PPV 16.2" front brakes with 6 piston Brembos. Quite the process to install the bigger backing plates with the front axles block access to the hub bolts. I can see why many don't change the backing plates.
Front calipers need a washer to align to the rotors and stock brake line works. Still need to bleed the brakes then will repaint my wheels while they are off.
MrMonte
MrMonte
With those 16.2" rotor & 6 piston calipers I've read gas mileage takes a hit. I've never seen a tank less than 20mpg in the 80K + miles that I've owned it. Has 134K miles now.
My 1st 50 miles after the new brakes I was at 17.7mpg. Have about 200 miles on the brakes now and last 50 miles was 24.2mpg even with a few red lights. Will be interesting to see what the next tank ends up as I filled it yesterday.
When I installed the 305 wide 33" tall tires I calibrated my speedo to GPS.
tc8510
TX
Looking good! Do you have the part numbers for everything you installed in the front? I have Brembos in the rear. I want the front to match!
MrMonte
MrMonte
Just got back from a 7 day roadtrip and the big brakes didn't hurt the mpg too bad. Lot of mountain driving so +4,000ft elevation changes, rain, snow & high winds with over 1,000 miles of driving and got 22mpg. Also had a few remote warm up starts, many drive thru stops & 80mph speed limits
I bought my front parts from Rock Auto except for the washers to center the calipers that came from Amazon. List below should help.
Fronts:
Rotors (2): Powerstop AR82209EVC. https://tinyurl.com/4jzyjprk
GM 6 piston caliper - left: GM 84793057: https://tinyurl.com/35ct3nbe
GM 6 piston caliper - right: GM 84793058: https://tinyurl.com/y9dtxcz4
GM caliper bracket bolts (4): GM 11612265: https://tinyurl.com/yx7b5jc6
GM banjo bolts (2): GM 11569590: https://tinyurl.com/4h9xyufh
GM crush washers: https://tinyurl.com/bdd4z9df
Powerstop brake pads Z372407: https://tinyurl.com/4jb6xad2
Washers (to mount between the caliper and the spindle): https://www.amazon.com/dp/B0BX43JS5Q
Rear:
1 x https://ctsvbrakeswap.com/collectio...ck-suv-4-piston-c7-rear-big-brake-bracket-kit
1 x GM 1722716 caliper (Right passenger side)
1 x GM 1722715 caliper (Left driver side)
1 x Power Stop Z261718 rear brake pads
2 x Raybestos 581032P rear brake rotors
2 x GM 11569590 Banjo bolts
2 x GM 22968938 Disc Brake hardware kit (the brake pad posts that run through the caliper)
Ericdd
Fronts:
Rear:
How much did the whole kit run you?
Ossipeelake
