West 1
- Joined
- Jan 20, 2023
- Posts
- 649
- Reaction score
- 1,390
Mine is bone stock from 2008 tune but a few years ago a new Techm was installed maybe it is updated? It wouild still be GM program though.
You would be very interested, if you fully appreciated that a thorough and proper engine tune also improves durability and longevity, not just performance.I have no interest in modifying the engine tune.
So here are some pics of some of the things I have changed. It not anything major but I think definitely helps a lot.
Torque converter slip, you want to zero out all desired slip tables even though my 6.2 doesn’t have dod I still went in and zeroed out all the tables for it.
I have read that this will prolong pr valve life because when slip is desired the valve is moving back and forth rapidly to achieve the amount of desired slip.
Shift points. In the shift schedule I changed shift points to extend through gears a little more.
Thanks for the info, @MWD_CTSV . I have disabled lockup in 1-4 with my original converter and intend to reenable lockup (but with zero slip) when I install a new converter, so I'll have to find out more info about whether their clutch material can be used with zero slip.
Yes, TCC lockup (even with slip) is a lot less heat than no lock. In the mountains on some tight curves I saw over 200 really quickly in the lower gears with no lockup. 4th is the weakest clutch vs 5&6, so I chose to only lockup 5&6, but that has a definite negative when it comes to running extended use in 4th vs the excessive heat created.I thought keeping the converter in lock up up would be a good thing for keeping heat down.
I had 4th gear unlocked and a good ways through 5th I test drove it and immediately noticed higher trans temps like up to 170 pretty quick. I changed it to have lockup in forth and a little lower in 5th and also run 5th out a little more in part throttle and trans temps came down with the converter being in lockup more.
With this luk being a multi disk clutch I thought it would be a good thing.
I’m no expert by any means though
That is a good data point to show that the Luk is calibrated to work with the stock programming. Presumably the dual clutch can dissipate the friction and heat across more surface area to greatly improve the operational lifetime.Why do we want to keep the converter unlocked.
Especially in tow/haul mode the added stress will build unnecessary heat and having a dual disk tcc that is rated for way more it should not have a problem.
Is there something I don’t know about with the 6l80 that would make it need this.
I’m seeing anywhere from 40-75 psi of tcc line pressure when it’s locked depending on how much throttle is applied.
Yes, it is. Look back at your own post. The title of the page has TC0017 in it twice. Dunno why it's not on the product page itself.Is this the same as the TorCon? All the other vendors say the part number is TC0017. I don't see that number on this listing nor do I see "TorCon." Price is quite a bit lower than all other vendors, even Amazon, but I'm not sure it's legit?
Yeah I guess it is, thanks for pointing it out. When I was typing out the post and pasted in the link it was just the gibberish long hyperlink, so I didn't see that text before I posted. I am still a little nervous just because I've never ordered from them before and haven't heard much, but I went ahead and pulled the trigger. We'll see how it goes. Total price with shipping and tax: $431.Yes, it is. Look back at your own post. The title of the page has TC0017 in it twice. Dunno why it's not on the product page itself.
If you're still concerned, RockAuto has it for $348.79 as of this writing. The RA page has both "TC0017" and "TorCon" on the "info" page.
