PsychedDenali
- Joined
- Feb 12, 2026
- Posts
- 1
- Reaction score
- 2
I had just changed the thermostat on my 2016 GMC Yukon XL Denali with the 6.2. Everything went fine but now my temp reading on the dash is pegged at 210 and will not move from it. I have checked with a scan tool and the ECT temp is reading 190 degrees and everything seems to be working fine except for the temp readout on the dash. I have tried clearing codes and then disconnecting the battery but the issue persists. This issue only started today when it started reading zero because the thermostat was stuck open. Before then the temp readout on the dash would work fine. Any help is greatly appreciated.
EDIT- Everything was working as it should I just was overthinking the temp readout and it doesn't help I haven't been a mechanic in a while.
