Crunchy Suspension when cold
Whofartedwasntme
Hope everyone is staying warm. 2016 Tahoe LTZ w/air suspension. Anyone have a crunchy suspension (front only) when it’s cold out. Once car warms up it goes away. I am thinking Sway bar bushings just need replacing? Anything else to look at? Thanks
Big Mama
Virginia
Usually bad bushings will continue to make noises. Can you describe what happens? Can you feel it in the steering, alignment, or when going over bumps? What’s it like after warm up?
W
Whofartedwasntme
Only over speed bumps etc. no issues with suspension or alignment. Goes away when car warms up. No noise when leaving home garage.
15burban
Wisconsin
What's cold? Freezing like 32 degrees or 20 below 0? Everyone's opinion is different.
Not apples to apples but on my pontiac car when it's -10 degrees or colder it feels like the oil in the strut freezes and will get some good thuds hitting potholes.
W
Whofartedwasntme
Prob 45F or below
Should have mentioned the struts are all newish (7k miles ago). Prior owner did them. BWI is the brand.
I would still suspect one of them regardless. Seems like one is sticking when cold/sitting and then starts moving again as it warms up, kinda like an old man in the morning!
Big Mama
Virginia
As James stated, essentially if the previous owner is what you’re going by. At a minimum check the top strut fasteners and the lower bolts.
JasonW4141
