Side Mirror Actuator Correct Part # ?
cbohannon25
I'm getting around to fixing the side mirrors on my 07 tahoe and need a little help. Its an 07 LT with power fold and I would assume memory but since I bought the car in 2022 they have never worked. The power fold function on both is broken but I have a good grasp on that fix. What i'm struggling with is the glass actuator on both sides is broken as well and there are so many options i'm not sure which is the correct one. I would assume it's a power fold but there is a 1st design and 2nd design. Also with the prices of these actuators and the glass (my driver side glass is cracked) it seems it may be a better deal to buy a used mirror and scavenge parts off that? Just wanted some advice :)
Also was curious if anyone has ever repaired these little actuators? I saw somone on ebay was selling the motors and the gears but i tried to split mine to find the issue and had no luck.
Go to GMPartsDirect.com, enter your VIN, go to the Body section, and look for the exploded diagram of door and mirror. You should find what you are looking for along with the correct part number. And, the cost will be significantly cheaper than the local dealer.
salijema
Sorry old thread, but I'm wondering if you found an answer. I also have an 07, but a Tahoe XL, power fold mirrors with signal light. Right side actuator (up/down, left/right) stopped working years ago. Just recently replaced the power fold motor, so decided to look into actuator. According to all the GM parts websites, the part I believe I need, 15874998 with 3 connection points, is discontinued. I think that it's been superseded by 25808706. Can anyone confirm that? Problem is, that 25808706 has ONE 7 or 8 pin connector, not 3 connectors like my existing one.
Does anyone know of the wiring change procedure to use the 25808706 in place of my 3-connector 15874998?
Also, searching around the internet, I saw a couple other actuators, with 3 connections like my original, but identified as part number 25804867. Wonder if that is an interchangeable part? I also saw another 3 connector actuator on eBay, but no part number, so might take a chance on that one if I can't convert my wiring to use the 25808706 that is available.
Hope this makes sense.
Thanks in advance.
Sorry old thread, but I'm wondering if you found an answer. I also have an 07, but a Tahoe XL, power fold mirrors with signal light. Left side actuator (up/down, left/right) stopped working years ago. Just recently replaced the power fold mirror, so decided to look into actuator. According to all the GM parts websites, the part I believe I need, 15874998 with 3 connection points, is discontinued. I think that it's been superseded by 25808706. Can anyone confirm that? Problem is, that 25808706 has ONE 7 or 8 pin connector, not 3 connectors like my existing one.
Thanks in advance.
Post the last 8 digits of your VIN to this thread and tag @915_Tahoe and ask for correct part numbers and availability.
_GMAN_
Did yoy
Thanks in advance.
ever rectify your mirrors?
spectol
