New state , new truck , who dis
05Single
05Single
afraid of the dark
So tore them apart just to add rgb strips to the strips in the headlights. More I dug in more I wanted to add work to myself lol.
One of the easiest mods is passive demon eyes. Plastidip red for the effect. Make sure to lay down white first as a base to brighten up the red. This goes for any painting. Black to darken , grey to keep neutral.
05Single
05Single
afraid of the dark
Did a full interior detail while it’s blown apart. Hid all the oem wiring . Upgrade speaker wire. Started on headliner that’s been out for a year just sitting in my spare room. Properly mounted the amp so it’s not just sitting in the floor behind the passenger seat. Threw the oem storage cover back in.
05Single
05Single
afraid of the dark
Have t installed b pillar speakers yet. Cheap ds18s , should be better than the oem which actually still work fine. Painted the red black. Red looks tacky imo
Any ideas how to patch up the holes in the headliner? What can I use? I want a smooth/shaved headliner.
05Single
05Single
afraid of the dark
Currently don’t have dome lights so threw this in just for fun. Surface mounted my tweets so they’re not sticking out as much, later I want them behind the panel with a face grille like the Tahoe had.
Added lights to the backyard for Christmas.
Then added some to the front. All rgb all separately programmable.
05Single
05Single
afraid of the dark
As I’m posting all this , Happy New Year from Medford , OR!
2025 was normal at first then it progressively got worse through the year and ended in a shytsho. Can’t catch a break. To be honest nothing has gone right since I moved to AZ. But 2026 needs to be a major change, not looking back at all.
05Single
05Single
afraid of the dark
I guess there’s been a few more mods but almost everything is mock ups and no follow throughs.
So all the front yard lights are just ones I brought over
from the back yard. Just lazy decorating but turned out to be pretty sick. Rest of the year my backyard looks like this.
05Single
05Single
afraid of the dark
Removed the cloth on the upper panel insert . Will rewrap them with the same material as headliner. The armrests were coming apart so I had them tacked and stapled.
05Single
05Single
afraid of the dark
Picked up the most hated grille for any 99-06 trucks.always had an idea for the Tahoe, bothered me so much I had to try it on the Silverado. Now obviously I’m not going to leave it like this. But I had an idea of just the center bar and billet pieces from headlight to headlight. Then also wing pieces on the end for an open grille in the middle but still borders between the lights. Can also be done with a Tahoe front. Colormatch would be the finishing touch but you get the idea.
Added the popular hood light everyone is getting and adding to their brand new $70k trucks (so tacky and ghetto looking imo) cringe. But instead I mocked it up in the middle and im kinda diggin the look. None of these are permanent, just messing around with ideas.
05Single
05Single
afraid of the dark
More ideas and visions I’ve had for years coming to life ….sort of. LED glow looks wild behind a full billet grille. Got a newer grille but it’s just too tall to work in a 03+. You can see where it just barely cuts into the corners of the headlights. Lots of shaving and cutting just to not have it work. But I think it will work perfectly on a 99-02/tahoe grille, hd in particular. So probably a side project later for someone.
05Single
05Single
afraid of the dark
Been wanting to change my face , gauge face that is. Little peek of what gaugewerx work looks like, kinda sloppy for what he charges. I expected perfection but that rarely exists these days.
Any idea why only one out of 8 pads is destroyed? Been hearing a grinding noice, kept getting worse. I’ve never changed the brakes so I figured they were do. Changed the fronts just to hear the same grinding, was the rear, fronts were fine, so was half the rear. Kind of a waste of $500 in brakes just to replace one pad. But everything was already installed. Not exactly how I wanted to do it. I wanted to get 07+ brakes like I did with the Tahoe but I was in a time crunch and had to get what VatoZone had.
05Single
05Single
afraid of the dark
So the blue looks sick with led backlighting and independent lit needles. Never seen this particular face done like this.
And the glow face looks even wilder with the indigo light and white lit Escalade needles, again never been done before, just needs some pink for that Miami vice look that’s so popular now lol.
I don’t know which one to go with. I like both a lot.
strutaeng
Dallas, Texas
View attachment 475233View attachment 475234View attachment 475235
View attachment 475227View attachment 475228View attachment 475229View attachment 475230View attachment 475231View attachment 475232
A sticky/seized caliper slide pins will do that.
Did you figure out the headliner infill? Maybe 1/4 plywood held in place with epoxy?
Cool post BTW. I'm surprised I've never seen it and been here a few years...
05Single
05Single
afraid of the dark
That’s cause I haven’t posted for a few years, not much had been done. But thanks. The cool thread is my Tahoe one lol.
So the pins are likely the same and it will do the same later on? ‍♂️
This guy on a Chevy fb group suggested spray foam. He’s done really nice interiors for these trucks.
05Single
05Single
afraid of the dark
I like this look the best
It was a clean look, but those wheels got more and more popular. Even though I had the chrome wheel skins I had to change it up. Every single cab on ig and here in az has those wheels.
05Single
05Single
afraid of the dark
2026 and we still can’t use mobile emojis on the interwebs?
Have t installed b pillar speakers yet. Cheap ds18s , should be better than the oem which actually still work fine. Painted the red black. Red looks tacky imoView attachment 475146View attachment 475147View attachment 475148View attachment 475149View attachment 475150View attachment 475151
View attachment 475152View attachment 475153View attachment 475154
Curious why the stock speaker is an 8 ohm instead of 4. You replaced with a 4 ohm. Any difference in the sound? Or anything else?
05Single
05Single
afraid of the dark
Haven’t installed yet. Had to leave state. Install in a couple weeks but should be a better sound in theory lol
05Single
05Single
afraid of the dark
There is one mod that’s my favorite yet nobody noticed them :bawl:
adventurenali92
Big Bear Lake, ca
More ideas and visions I’ve had for years coming to life ….sort of. LED glow looks wild behind a full billet grille. Got a newer grille but it’s just too tall to work in a 03+. You can see where it just barely cuts into the corners of the headlights. Lots of shaving and cutting just to not have it work. But I think it will work perfectly on a 99-02/tahoe grille, hd in particular. So probably a side project later for someone. View attachment 475207View attachment 475208View attachment 475209View attachment 475210View attachment 475211View attachment 475212View attachment 475213View attachment 475214View attachment 475215View attachment 475216View attachment 475217View attachment 475218View attachment 475219View attachment 475220View attachment 475221View attachment 475222View attachment 475223View attachment 475224View attachment 475225View attachment 475226
I agree the wire mesh style grill kinda looks janky but I like it with the solid backlit Chevrolet bar that’s pretty cool!
JamesinAbilene
