New ride? Opinions wanted!
Campie
Hey guys, looking at a 2017 Yukon Denali XL with 139,000 miles. Probably around $20,000 plus tax. Wondering if anybody has access to a build sheet? VIN is 1GKS2HKJ8HR224782. Looking to upgrade from a 2007 Yukon Denali. Hoping for more reliable, towing and long-term performance. Thanks!
All the usual stuff for checking out a potential new-to-you vehicle. I'm not sure where you can find a build sheet, but someone here in this Forum ought to be able to give you some guidance.
Give some thought about what you are, or are not, going to do about the AFM feature in the 2017, something that you did not need to be concerned about in the 2007.
Carfan
For $9.99 you can get a window sticker from Monroney Labels.
Campie
Campie
Right, thinking I’d probably do the the delete, one way or another. Maybe with just the plug-in. I had found the other thread about “upgrading” but it doesn’t talk much about towing. Any thoughts on better towing with the XL vs the standard Yukon? What about the suspension, and for towing? Is a 2017 new enough that the suspension would last for another 5 years? Our 2007 had already had the air-ride removed.
2016Dom
Albuquerque NM
I would recommend cleaning the intake valves, I did a walnut shell cleaning and felt an improvement, and add a catch can.
Most folks believe that the Yukon XL handles towing better than the standard Yukon, because of (1) the Yukon XL's longer wheel base provides a more stable towing platform, and (2) the Yukon XL typically has a larger motor in it.
Bigburb3500
How much weight do you plan to pull and how regularly?
Marky Dissod
8L90, 3.23, no special towing package or provisions mentioned, just a hitch. 4WD has Lo range available.
They're both 6.2L, yeah? If the '07 Denali's axle gear is 3.08 or 3.23, then yes, the '17 will tow better.
If you got lucky and the '07 has 3.42, then they'll be a lot closer in terms of towing performance.
If you are under the impression that the '07 is less reliable, then sell it to someone who will fix it up and keep it running til at least 2037.
Campie
Campie
The 07 is dying. It pulls just fine but we’ve got transmission codes and a high metal content in the oil. The metal in the oil causes the crank sensor to malfunction and it dies under load - which is pulling our camper. We can’t do our own work so… I’d love to get it to someone who could rebuild it. It’s an amazing car. The body is almost perfect, the interior is ok. But we need to replace it.
Marky Dissod
'07 is dying. It pulls just fine but we’ve got transmission codes and a high metal content in the oil.
The metal in the oil causes the crank sensor to malfunction and it dies under load - which is pulling our camper. We can’t do our own work so ...
Bet a 6.0L L76 / LY6 / L96 / LC8 COULD be cheaper to find and install, than a newer vehicle ...
Either way, good luck. Neither is easy, I know.
Campie
Campie
It’s the same 6.2 as the ‘07 but it’s the L86. The ‘07 has the L92.
Campie
Campie
We thought of that but what other issues with drivetrain, electrical, etc would we fine down the road-literally!
Bigburb3500
Our camper is little - 20’ long and about 5500 lbs but it’s 8’ wide and 10 1/2’ tall so it’s a giant parachute!
as everyone says, if you can add a trans cooler that will seriously help the truck. But overall 5500 lbs seems right in line with what this truck can do. Others can speak better to this.
Campie
Campie
It already has the standard Denali transmission cooler. And it does pull just fine - until we get off the highway and it just - dies… no screams of pain, no struggles, just nothing….
vcode
2017 has the 8 speed. Hard pass......
Campie
Campie
Say hello to our new-to-us 2018 Yukon Denali! L86 with 10 speed transmission, 33k, just about perfect vehicle! Got the 6 yr, 60k Platinum warranty so looking to add a dongle for AFM delete when towing our camper. What’s the best/easiest dongle that we can plug and unplug as needed?
Tupapi
