Stupid question about flex fuel
Bagherra
Army
Va Beach, VA
I ran my VIN thru a decoder and it says E85 MAX.
Im assuming that I can use E85?
Thanx for ya'lls patience:)
1GKS2CKJ3GR186346
These are the RPO codes for your truck. Check out code FHO. I do not think you will have a yellow gas cap or sticker inside the fuel door if yours is capless. What this means is that the engine is capable of running E85 only if you add the alcohol content sensor and activate the tables in the computer. Don't run low octane fuel or E15/88 either. That high performance 6.2 needs 91+ octane or straight E85. Puerto Rican truck eh?
RPO Code RPO Description
1SZ DISCOUNT OPTION PACKAGE
4EZ INTERIOR TRIM COCOA / DARK ATMOSPHERE
5SA PACKAGE DENALI OPTION 1
6ZN COMPONENT FRT LH COMPUTER SEL SUSP (6ZN)
7ZN COMPONENT FRT RH COMPUTER SEL SUSP (7ZN)
8X2 COMPONENT RR LH NON-COMPUTER SEL SUSP
9X2 COMPONENT RR RH NON-COMPUTER SEL SUSP
A31 WINDOW POWER OPERATED, ALL DOORS
A45 MEMORY SEAT ADJUSTER, MIRROR, POWER, DRIVER PERSONALIZATION
AG2 ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL
AKJ WINDSHIELD STYLE SHADE BAND
AKK WINDSHIELD STYLE ACOUSTIC PVB
AKO WINDOW TYPE PRIVACY
AKX WINDSHIELD TYPE SOLAR ABSORBING
AL0 SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
AN3 SEAT FRT, INDIVIDUAL (NON BKT)
AP9 NET CONVENIENCE
ARL PLANT CODE ARLINGTON, TX, USA
AS8 SEAT THIRD ROW 60/40 BENCH, POWER FOLD
ATH LOCK CONTROL, ENTRY REMOTE ENTRY, EXTENDED RANGE, PASSIVE ENTRY
ATN SEAT RR BUCKET, POWER CONFIGURABLE
AU3 LOCK CONTROL SIDE DR, ELEC
AXP VEHICLE TYPE MULTI-PURPOSE PASSENGER VEHICLE
AYQ RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS FRT, FRT SEAT SIDE FRT INBOARD SEAT SIDE, ROOF SIDE
B30 COVERING FLOOR CARPET
B58 COVERING FLOOR MAT, FRT & RR, CARPETED INSERT
B85 MOLDING B/S EXTERIOR, BRIGHT
BTM SWITCH ENGINE START, KEYLESS
BTV REMOTE START ENGINE
BVE STEPS, RUNNINGBOARD SIDE
C25 WIPER SYSTEM RR WINDOW, INTERMITTENT
C49 DEFOGGER RR WINDOW, ELECTRIC
C6A GVW RATING 7, 300 LBS
CE1 WIPER SYSTEM WINDSHIELD, PULSE, MOISTURE SENSITIVE
CF5 ROOF SUN, GLASS, SLIDING, ELEC
CJ4 HVAC SYSTEM AIR CONDITIONING, FRT & RR ELECTRONIC CONTROLS
D07 CONSOLE FRT COMPT, FLOOR, CUSTOM
DCP PROCESSING DIRECTIONS & CONNECTIONS SERVICE PACKAGE
DD8 MIRROR I/S R/V LT SENSITIVE
DL3 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED POWER FOLDING, TURN SIG IND, LT SENSITIVE, COLOR
EF7 COUNTRY UNITED STATES OF AMERICA (USA)
FE9 CERTIFICATION EMISSION, FEDERAL
FHO VEHICLE FUEL GASOLINE E10
G80 AXLE POSITRACTION LIMITED SLIP
GU5 AXLE REAR 3.23 RATIO
GXG PRIMARY COLOR EXTERIOR, IRIDIUM MET (121V)
H4W INTERIOR TRIM CONFIG LEATHER, LEVEL 4, COCOA / DARK ATMOSPHERE
I16 ENGINEERING YEAR 2016
IO6 RADIO INFOTAINMENT SYSTEM - UPLEVEL HMI, ENHANCED CONNEC TIVITY, EMBEDDED NAVIGATION
JD9 BRAKE VAC POWER, 17" DISC/DISC, W/VSES, 7700 LBS
JF4 PEDALS ADJUSTABLE, POWER
JL1 CONTROL INTEGRATED TRAILER BRAKE
K34 CRUISE CONTROL AUTOMATIC, ELECTRONIC
K47 AIR CLEANER HIGH CAPACITY
K4C CHARGER INDUCTIVE PORTABLE WIRELESS DEVICE
KA6 HEATER SEAT, RR
KB6 HEATER SEAT, COOLING, FRT
KC4 COOLING SYSTEM ENG OIL
KI4 RECEPTACLE ELECTRICAL, ACCESSORY 110 VOLT
KNP COOLING SYSTEM TRANS, HD
KW7 GENERATOR 170 AMP
L86 ENGINE GAS, 8 CYL, 6.2L, SIDI VVT, AFM, E85 MAX, ALUM, GM
M5U TRANSMISSION AUTO 8 SPD, 8L90
MAH MARKETING AREA US, PUERTO RICO/USVI
N38 STEERING COLUMN TILT, TELESCOPING, POWER
NKC NOISE CONTROL SYSTEM, ACTIVE NOISE CANCELLATION
NP5 STEERING WHEEL LEATHER WRAPPED
NQH TRANSFER CASE ACTIVE, TWO SPEED, SWITCH ACTIVATED, ALUM
NT7 EMISSION SYSTEM FEDERAL, TIER 2
PCJ CONTROL SALES ITEM NO. 103
Q7M WHEEL 22 X 9.0, J, ALUMINUM, DESIGN 3
QST TIRE ALL P285/45R22 SL 110H BW AL3
R9N CONTROL SALES ITEM NO. 89
RC4 TIRE SPARE P265/70R17 SL 113S BW
RUF WHEEL SPARE 17 X 7.5, J, STEEL, DESIGN 1
SAF LOCK SPARE TIRE, HOIST SHAFT
SLM SALES PROCESSING STOCK ORDERS
T3U LAMP FRT FOG
T4F HEADLAMPS HIGH INTENSITY DISCHARGE
TC2 BODY EQUIPMENT LIFT GATE, POWER, HANDS FREE
TQ5 SENSOR HEADLAMP HIGH BEAM AUTO CONTROL
U2K DIGITAL AUDIO SYSTEM S-BAND
U2L RECEPTION HD
U42 ENTERTAINMENT PKG REAR SEAT, SINGLE DISPLAY, REM CONTROL, AUX JACK 2-WIRELESS DUAL CHANNEL HEADPHONES
U77 ANTENNA RR WINDOW, RADIO
UD5 PARK ASSIST FRONT AND REAR
UE1 COMMUNICATION SYSTEM VEHICLE, ONSTAR
UEU SENSOR INDICATOR FORWARD COLLISION ALERT
UFG SENSOR INDICATOR REAR CROSS TRAFFIC ALERT
UG1 OPENER GARAGE DOOR, UNIVERSAL
UHS DISPLAY INSTRUMENT DRIVER INFO ENHANCED (MULTI COLOR ENHANCED GRAPHIC )
UHX LANE ACTIVE SAFETY KEEP ASSIST
UJM TIRE PRESS INDICATOR MANUAL LEARN
UK3 CONTROL STEERING WHEEL, ACCESSORY
UKC SENSOR INDICATOR SIDE OBSTACLE DETECTION ENHANCED
UMN SPEEDOMETER INST, MILES & KILO, MILES ODOMETER
UQS SPEAKER SYSTEM PREMIUM AUDIO BRANDED WITH SURROUND AMPLIFIER
UTJ THEFT DETERENT ELECTRICAL, UNAUTHORIZED ENTRY
UV6 DISPLAY HEAD UP
UVC VISION REAR VIEW, MONO
UVD HEATER STEERING WHEEL
V54 LUGGAGE CARRIER ROOF, PAINTED
V8D VEHICLE STATEMENT US
VFF VIDEO FORMAT REGION 1, NTSC
VH9 ENVELOPE OWNER INFO MAN
VHM PROGNOSTIC SYSTEM VEHICLE HEALTH MANAGEMENT
VK3 LICENSE PLATE FRONT FRT MOUNTING PKG
VRK VAA/COMPONENT REL ROOF TRIM
VT7 OWNERS MANUAL ENGLISH LANGUAGE
VV4 COMMUNICATION EQUIP MOBILE INTERNET CONNECTIVITY
WMG VIN MODEL YEAR 2016
XL7 FREQUENCIES RATING 315 MHZ, LONG DISTANCE
Y86 SALES PACKAGE ESS 1B
Y91 MERCHANDISED PKG LUXURY EDITION
Z82 TRAILER PROVISIONS SPECIAL EQUIPMENT, H.D.
Z88 MARKET BRAND GMC
Z95 CHASSIS PACKAGE MAGNERIDE
ZY1 COLOR COMBINATION SOLID
Bagherra
Bagherra
Army
Va Beach, VA
Tell me more of this sensor and tables gettin turned on please..
E85 worth the trouble of adding a sensor and getting tables turned on?
it can be done the plug-n-play e85 sensor kit is about $300, plus whatever the tune would cost.
but otherwise they stopped offering the e85 option about 2015 because the CAFE credits they got for it were no longer any good to trade or sell. So it was not worth there effort anymore to allow e85.
you might be able to find a sensor setup for less but it will require modifying to install.
https://www.lethalgarage.com/collec...e-flex-fuel-kit-2014-2019-chevrolet-silverado
NYBRD
Cost me about 130 bucks maybe in parts, and asked my tuner from BBP to let the car run on e85
Dh1280
