champwhiteitr
- Joined
- Aug 28, 2025
- Posts
- 22
- Reaction score
- 11
Give it a day or so, it will recalibrate and be fineView attachment 466215lights on after dead battery replacement any ideas? Thanks in advance
It’s been over a week like thisGive it a day or so, it will recalibrate and be fine
I replaced the battery twice to be sure it wasn’t a defective battery, metered at 14VWhat was the voltage of the new battery?
Any other messages or codes? I don't have one of these new ones but Pete does. @PG01I replaced the battery twice to be sure it wasn’t a defective battery, metered at 14V
No other codesAny other messages or codes? I don't have one of these new ones but Pete does. @PG01
What I have noticed is the only thing I cannot read is the ABS, scanner faults out, I will check all my abs fusesWould the ABS warning have anything to do with it? Just asking.
Yeah, I should've caught that. 14v is too high for a battery. I think 12.75 is the most we should expect to see from a fully charged 12v battery.Metered with a DVOM, or with the dash gauge?
Fluke meterMetered with a DVOM, or with the dash gauge?
I have a new one I will replace with when I get homeI would check your ground cable on the battry…
Fluke meter
Yes sorry 14v running 13v offClearly this (14v) was with the engine running.
Replace with new OEM and same issueI would check your ground cable on the battry…
Did you make sure the ignition was not in the on position when the new battery was installed? You shouldn't need it but do you have access to a scan tool?View attachment 466215lights on after dead battery replacement any ideas? Thanks in advance
check the ground strap on the (electric) power steeringView attachment 466215lights on after dead battery replacement any ideas? Thanks in advance
