How can i fit these tires
Big 'ol Boner
I've just recently been looking at Tahoes. I have been wanting an avalanche for about 3 years now but today i saw the most badass tahoe it instantly changed my veiws. I was parked outside a boat shed and a 2007-new white tahoe pulled up sittin on 18" rockstar XD's and 295/70 18 trail grapplers. I didnt get a chance to talk to the man because i was in a hurry but if i was to get a tahoe i was wondering what kind of expenses i would be looking at to fit those. I mean just pricing the rims and tires is already like 2.5K but......I know with avalanches you can fit up to near 34's if you trim and get the proper backspacing and level it out and all that shit. I'm guessing the same applys to tahoes but im not sure.
Conor
"Bob's your Uncle"
Seattle, WA
You can get a leveling kit for the front 2" and a rear 1" spacer that should not be a problem fitting those tires. I will say however that the Rockstar wheels are pretty well played out. But to each his own. Good luck in your search Thomas
Modded
That Guy
I support eveything Conor said above, esp. the part on Rockstars being played out!
Rockstars to lifted trucks are like high heels to Prostitutes, toooooo common.
B
Big 'ol Boner
yeahhhhhh i know. But i swear to god those things looked awesome with that contrast of the white Tahoe. I see my fair share of rockstars in south carolina but not enough to get tired of them. I mean i wouldnt have any problem with getting different rims and all that but im just saying that if i could have a look THAT is the one I would want no doubt. Thanks for the info though that helps out a lot. I was looking around thinking you would need a 4" or something but this system would fit the budget a lot better. Which would be the best/cheapest way to get the 2" front with the 1" back?
---------- Post added at 08:29 PM ---------- Previous post was at 08:27 PM ----------
oh yeah. That high heels to prostitutes was a good analogy. lmao
B
Big 'ol Boner
2" in the front can be got pretty easy. The Belltech from lift struts can do it, but if not, I say just get a spacer up front. Or you can rock the Rancho ReadyLift kit and get almost 2":http://www.readylift.com/c-45-chevy-avalanche-1500-2007-2010-2wd-4wd-6-lug-adj-10-15.aspx.
I would run an Eaby 1" spacer out back too, Belltech and many other companies make some that some type of plastic, maybe polyurethrane.
I dont know much about tahoes but avalanches you can just turn up the torsion bars and get about 2". Can you do the same with tahoes? I mean im lookin to save some cash and stuff (but yet im lookin at rockstars and trail grapplers.....) but if i could just crank the T bars and save $250 im all for it. Id probably still need that spacer in the back though wouldnt I?
Modded
That Guy
The new model (07-Up) Tahoe, Avalanche's and Suburbans do not have torsion bar front suspension. Instead they have strut/coliover front suspension.
Makes for a better ride thats why.
The only way to get a lift up front on the newer models w/o spending alot is to use a lift strut/coilover (like Bilstein leveling strut, the Bellteh one, or ReadyLift), or to use spacers.
B
Big 'ol Boner
ive been looking around and ive found a good front spacer. It's a 2" front strut spacer from pro comp on 4wheelparts.com and it goes for about $122 but i cant find any back blocks. Ive gone to all the major parts websites and none of them will fit tahoes. What do most people on here use for back lifts?
Modded
That Guy
The rear uses a coil suspensioon, so you would be looking for coil spring spacer, not a block. Blocks woulf be on Silvys or Sierras with a rear leaf suspension.
Spacers for the rear are also at 4WP, or Ebay.
B
Big 'ol Boner
damn i got a lot to learn about tahoes. Im not use to SUVs at all. Aight well i found a super lift one for like 43 monies. It goes up 3/4 in and i figure that should be good. What do you say?
Modded
That Guy
Thats would be enough since the front is only 2" lower than the rear. So 3/4" will help to get rid of the Cali Lean.
Mattjr79
Lilburn, GA
Check ebay for your front spacer...2 buddies of mine with silvy's got there spacers for like $80 bucks...just saying, since your trying to save some cash
B
Big 'ol Boner
aight ill do that. i got a wakeboard with bindings on there brand new worth $800 for $339 so i kinda trust ebay. But i figure with the pro comp front spacer for the 2" in the front and then that superlift 3/4" spacer in the back i should clear with minimal trimming and rubbin right?
---------- Post added at 09:00 PM ---------- Previous post was at 08:48 PM ----------
looking on ebay i cant find coil spring spacers or strut spacers. So i guess id have to go from the store. but the pro comp goes for like 122 and the superlift for 43 so together thats 165. I mean for that kind of price to fit those tires is hella good i think. So i guess i would just go with that system.
Conor
"Bob's your Uncle"
Seattle, WA
Look at the ReadyLift SST lift kits. It is a 2.5" front spacer and a 1" rear spacer.
Zed 71
Pacific NW
I'd recommend 2.5" up front and 1.5" spacers in the rear. 295/70/18s work out to be 34.26 inches in diameter theoretically. FYI, I have 285/65/18s on stock Z71 rims and had to trim ~2 inches off the front wheel wells. The back spacing on aftermarket rims will help though.
I have 2.5" front and 1" rear spacers and it is level. The reason I recommend 1.5" spacers in the back is if you frequently carry heavy loads or tow, the rear has room to squat.
Just my 2 cents.
B
Big 'ol Boner
Just my 2 cents.
yeah i would go with that but i dont plan on hauling any REALLY heavy loads. I mean the biggest thing id haul is maybe a 16' boat. And that's not heavy enough to make the back really squat. But ill prolly go with that kit that Conor was talking about with the 2.5 in the front and 1 in the back. I may have to do some trimming but its not that big of a deal unless theyre taking out my whole damn wheel well. But my uncle owns a car dealership and he looks around on the market for cars for our family. I told him to look for an 07 tahoe or yukon. I know they are about the same cars on the outside and inside but are they the same underneath? like would there be different kits i would need to order for a yukon instead of a tahoe?
---------- Post added at 09:32 PM ---------- Previous post was at 09:18 PM ----------
i think i found the one yall are talking about its a readylift 2.25 kit and it says it levels and lifts so im guessing that includes the back too. Theyre talkin about $330 which i still think is decent since last time i ordered a lift to clear 35s it was in the 2ks. But i bet this kit would work good instead of ordering different brand and size parts and hoping they work out like you want them too.
Zed 71
Pacific NW
The Readylift only includes the front. FYI I got the CCM 2.5"F/1"R for $125. Leveling kits will not allow fittment of 35s, a proper 4-inch lift kit is needed. NNBS Yukon and Tahoe have same suspension, but there is an autoride suspension option that is different. IMO a spacer is a spacer, so mixing brands is not a big deal.
Hope this helps.
B
Big 'ol Boner
Hope this helps.
thanks. well the tires that im looking at are not really 35s they are 34.26 which is close to an inch less than a 35. I believe those will fit wont they?
07warwagon
You will need atleast a 4" lift to clear those tires. I only say that because I have an 07 Suburban with 33" Nitto TrailGrapplers. I couldn't fit 35s without trimming the front bumper. But good luck to you.
B
Big 'ol Boner
DAMMIT. I had my hopes all up and shit. now im pissed as ****. it just depends on how much trimming. If its not a real big job i might just go with that. OHHHHH my god. that ruined my whole damn day.
CrackerJack135
