cold air instake
Spanky7
how much better is an aftermarket cold air intake then stock set up? What are the realistic gains in swapping out to something like a Banks Ram Air Intake?
lorax54
Denton, TX
Now, is it very minimal...regardless of what exhaust you have? I'm sure the Chevrolet put an air box on the engine to fit the type of exhaust they were planning to use. Is the minimal gain because the stock exhaust holds it back, and a better exhaust would be able to maximize the increased volume draw of the CAI? Does that even make sense?
S
Spanky7
good question, answers anyone?
TogaPC
Austin, TX
Stock airbox and exhaust are a good match. Let's remember that the key to making horsepower is moving as much air in and out of the engine as possible. If you increase the airflow as long as the computer makes up for it with the correct mixture adjustments you will make more power. That's why superchargers and turbos make much more horsepower.
The CAI does draw slightly cooler air depending on the setup and since the stock intake has a lot of baffling to eliminate noise it is more restrictive. It is fairly ineffective, however, to increase the flow in without increasing the flow out. Make sure when you choose an after market exhaust that not only does it sound better but the flow is better.
Once you reduce the restriction at both ends it's very important that you tune your ECU to compensate for the extra air flow.
So to answer your question...no, a CAI alone does not make much difference. Combine it with an exhaust and a tune and you will gain horsepower and throttle response.
2007tahoeGuy
Houston
You should have the same effect installing a K&N air filter as you would a CAI (at a much lower cost)...very little gain but you should feel something. From my personal experience, the CAI will give you a nice growl coming from under the hood off the line b/c the stock air box is also used to help lower intake engine noise.
And I just wanted hey, BTW. New to the forum!
TogaPC
Austin, TX
First off...welcome to the forum.
I would partially agree with you on the K&N drop in filter, especially if you do the swiss cheese mod. The biggest problem is the baffling in the stock intake which creates turbulence in the intake airflow.
Most of the CAI kits come with a very simple intake tube design that allows direct flow from the filter to the throttle body. The air also travels less distance which helps prevent heat soak and helps with throttle response since the distance from the MAF sensor to the combustion chamber is shorter.
These are all minor factors but they do add up.
As for cost...I don't see a huge difference between the drop in and the CAI. If you're gonna do it, might as well do it right.
K&N Drop In - $46.45
Spectre CAI - $123.95
Plus the CAI looks so much cooler...:)
brucebly
Tennessee
The K&N CAI is almost 300. It is made of much better materials and it is designed better to stop heat soak when stopped at red lights. IMO
KrautBurner
Bremerton, Wa
the biggest advantage to a "CAI" is the growl that will come from under the hood.
on open highway under optimal conditions, it may be good for about 1mpg too ;)
S
Spanky7
Thanks guys! I actually like the look of the Banks RAM CAI, that's what I would likely go with if I decided to purchase one. the extra mpg would make me most happy. I didn't buy this to hop up performace wise I guess, but maybe I'll add exhaust down the road, for right now, it has a decent sound in my book, and I think it is stock?! How could I tell if it was stock or other?
also just an FYI, when I took over this Hoe, it had a reading of 13.5 mpg average, now after 3 tanks of gas, the average is up to 17.6. In my 60 mile round trip my personal mpg read 19.3! I
mitchell315
does anyone know about ckeck engine light coming on after installing cai? put computer on it andsays low frequency on maf sensor? i heard maybe pulling baffling out of maf will stop light from triggering. anyone know if this is true? 98 tahoe 5.7
gen3usa
Vancouver, WA
im not exactly sure on yours but with the CAI the MAFS would notice the added air flow and try to change the computers fuel management, when i did my K&N i also replaced the MAFS with the Jet Performance module to account for any possible major air flow changes. never saw my engine light come on, however i did mine as a dual change mod! i havent heard anything about removing the baffle in the stock unit.
andrew383
indiana
It means there is oil from the filter on the maf..Take the maf off and clean it with maf cleaner..The "baffle" you see in there is to straighten/smooth the air out as it goes over the sensor..Its not worth it to remove it....
Im sorry you wasted you $$ on a "performance maf" but you would have been better off putting that money towards a real tune..Same goes with the TBS :)
Greg Bennett
Houston Texas
first mod to this gray beast: Bilstein 4600 rear, 5100 adjustable heights in front. thinking about supercharger but hennessy quoted 14k, dont think so! Id go for 5k all in. Any recomendations? Divorced wife got the house and workspace so I hire it out.
JennaBear
Resident Ninja
San Diego, CA
Hennessy is just a rebranded major name supercharger (ie. Whipple or Magnacharger). We sell all major brand name kits, and could get you one for WAY less than 14K!
drakon543
Hennessey puts out some serious ground pounders but your basically paying for the name not the equipment as stated by jenna most if not all thier stuff is just rebadged. Typical blown price then the extra 5+k for them to stick a badge on the back of your truck. If you actually live in thier area tho i hear thier home base customer service is outstanding. Still overpriced compared to what others including blackbear can set you up with.
johnsonwillie199
