latvius
Ariton Alabama
Replace the 4wd actuator. It was showing neutral, I bought the actuator but tried to replace the switch first. The new switch went neutral, then another day it would show in 4hi AND 4low, then another day it stopped working all together. After I replaced the actuator the switch was still dead and putting in the old one got everything going.
dps01
Senior Member
Navy Supporting Member
N. TEXAS
Took it in for an alignment afterwards.
That’s when the real trouble started….
Update….
Finally got it back after replacement of brake hardline.
The suspension parts selected may be overkill, but damn … the Tahoe rides and handles better than ever (maybe even better than when we picked her up in 2003…).
With the front and rear suspension overhaul and the Durafoam lower seat padding she is ready for the family adventure road trip…..
S33k3r
Dallas, Texas
Finally managed to source and retrofit a 2005 Escalade Platinum cooled/heated cupholder unit to my 2005 Denali XL, way more complicated then it should have been and had to buy a second unit to replace the tar and hair covered circuit board in the first one I bought. It was pretty difficult to find any info to help restore it, but now my drinks stay ice cold and dont dilute my drinks any more!
I've got a friend who supposedly reverse engineered these. If he has them up for sale, I'll post a link. Please let me know if there is any interest here. Thanks!
ivin74
05 NBS Nali
Htown, Texas
Has anyone changed out the whole tail light harness? How hard is it go get to the bundle connector. I'm thinking of doing this instead of just the individual sockets.
Not hard at all, wear glasses when you crawl under the vehicle to unplug the harness. Dust/dirt will get on your eyes if you don't.
5x10
Does it go hot after you make a hard turn?
No, was going straight down the road and it just started blowing hot, has happened twice
Turn the car off, come back in 15 mins and blowing cold again
Actually now that I think of it, both times it happened, it was blowing hot when I first started it up , I can try the rest , isn’t it just popping the fuse out for a minute or two ?
I actually don't remember. Maybe try a forum search, or even youtube. Pretty sure it's a different process between the manual and digital hvac units.
Scottydoggs
NJ
my hoe was doing this. new actuator fixed it right up. d/s kinda sucks to get to. i did it with the seats and console still in place. but if i had to do it again, id remove em for sure.
5x10
I saw on video , looked fairly easy, remove the ac fan cowl and it’s behind the console
Hard to reach some of the nuts?
latvius
Ariton Alabama
The hardest one is the cowl screw, once you remove it never put it back you don't need it, 2 screws will hold it up. The actuator screws are kinda ****** but not to bad. If you have dual zone you have an actuator on top as well BTW.
Escalade2007
