Chev or GMC gauge cluster in '07 Escalade
mikez71
You can choose between 3 displays. (See MIRROR settings below)
Unfortunately, you cannot customize which gauges are in which display.
Here's what I printed out and put in my truck, so I don't forget how to use it...
CONFIG MENU
engine OFF - BRAKE pedal & GAS pedal
engine ON - RES+ button & SHIFT+ button
HIGH IDLE
hold cruise SET button [ in park / off brake / park brake on ]
RPM adjust (SET - ) (RESUME + ) (1000-2000rpm)
STROBE LIGHTS
hold cruise CANCEL button [ off brake / cruise on ]
OPEN Windows
keyfob UNLOCK button 4x
CLOSE Windows
keyfob LOCK button 4x
Mirror UP
FACTORY DISPLAY
Mirror DOWN
BACKUP CAMERA
Mirror RIGHT
x1: OIL PRESS / COOLANT TEMP / GEAR / TCC LOCK (*)
Mirror LEFT
x1: SPARK / INTAKE TEMP / KNOCK RETARD / ETHANOL %
x2: MANIFOLD PRESS / TCC SLIP / MAF / TRANS TEMP
homesick
homesick
The Best Me I Can Be
Navy Air Force
CONFIG MENU
HIGH IDLE
STROBE LIGHTS
OPEN Windows
CLOSE Windows
Mirror UP
FACTORY DISPLAY
Mirror DOWN
BACKUP CAMERA
Mirror RIGHT
Mirror LEFT
Man, I appreciate you hanging in there. I have some reading and digesting to do.
joe
veteran111
