My passenger washer arm-nozzle ..clogged......
justirv
Fix, or replace the nozzle? Take apart & clean with compressed air? ( Driver's side is fine )
I have not had to replace (yet). I have found that an ultrasonic cleaner works well to break up deposits, and/or a soak in some slightly acidic liquid, like vinegar or citric acid.
mountie
mountie
Since, I can't raise the wiper very high, it's a pain, to get a good look at the sprayer. and how to carefully remove it... I disconnected the tube, and blew compressed air into it ( toward the nozzle )..... Air came out..... But now, it "bubbles" out of it, and sprays slightly.
I may have screwed up the nozzle tip? I'm going to buy a replacement, and then remove the arm to replace.....
mountie
mountie
I didn't find any videos , how to replace that nozzle.... So, I'll take pics....
justirv
Unless you stuck something in there (a needle, pin, etc.) the chances of you damaging the tip are low. Perhaps a syringe with tubing and warm vinegar soltuion might help clear up the obstruction? New always works as well. I like that solution when I just don't have the time or desire to mess around.
mountie
mountie
Using the air pressure, air did come out..... But it is a "messy" spray now ( mostly bubbling out - little spray). I will buy a new nozzle, then see if the air pressure caused the tube to leak behind the nozzle tip?
Now.... I will search, for somebody has that little widget in stock .... Wish me luck....
Buy the earlier version of the wiper arms. The 2000-2002 ones will allow you to raise them up higher above the glass. Other than that function they're identical. See this post for the comparison:
mountie
mountie
I search for a wiper nozzle FOR A 2000 TO 2007 YUKON..... Nothing available.
None of the parts houses has any for these years...... Not Amazon.....
I will attempt the stealer - dealer.....
probably a salvage yard... ( it's come to that?? )
I am not touching the one on my truck, until I have a replacement in my hand!
UP-DATE; Called my local dealer...... They transferred me to parts, as they left them a message to call me.......
3 hours later...... No return call. Dealers suck....
Probably not a part you can buy. So buy the whole arm. Note that the new ones don't come with splines in the mounting hole -- the splines get cut the first time they're installed.
mountie
mountie
The arms you selected, are 2 R/H wipers. The pic I posted are a correct set. The lower arm in pic, is the left hand wiper, with the nozzle farther up the arm. ( The R/H arm's nozzle is not as far up the arm, so it doesn't spray past the windshield.
( I just got my OEM, R/H arm from FedEx today )
kurtibm
Grand Canyon
Terrific.
The one you bought won't raise up very far from the windshield. You knew that, though. I love having mine where they will pull up almost vertical and stay in place to wash the windshield or clear it of snow. TEHO
mountie
mountie
The one I just got, is the original OEM, GM replacement..... The parts guy at the dealer searched online, showing all available GM dealer's parts....
He showed me the print out...... He said, " You just got the last one.... It's been discontinued and the Ft Meyers has the last one.
Woopee...
(( BTW...... Don't even ask me how much I had to pay for that thing from the 'stealer'..... :eek:
albac
