Transfer case or Front End whine/growl.
Saucy_Walnuts
NW Oklahoma
So I'm fairly new to GMs. I have a 2003 Yukon 4x4 With a NP 246 Tcase. I just picked it up for $2800. It has since developed a growl in either the front end or transfer case. When parked and truck off, I spin front driveshaft and it sounds a bit noisy. I've checked the fluid it's full but dark. As well as the front diff it's full but dark. It drives fine and switch's all 4x4 gears smooth and noise does not change in or out of 4x4. It seems to get louder under accel/ throttle load. Front end is tight and noise is only after 10-15mph. Could a Wheel bearing be a issue or CV axle? It sounds like its primary on the left side.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum, from Oregon.
In 2wd and going straight, can you move wheel slightly left or right, does the noise get louder? Tire tread chopped?
Saucy_Walnuts
Saucy_Walnuts
NW Oklahoma
Thank you, from Oklahoma.
No movement without the tires moving, steering is sight as heck. I just had tires put on Sunday. The ones that were on it had outside edge wear. Put it up on a jack a few mins ago. Spun tires no noise besides a slight break drag. And the noise does not get louder when turning. But does under acceleration, let off on the throttle it quiets a bit. Just a little note it has 176K on the clock. At stationary in park revving up it does not make noise.
I'm not saying this is the problem, but the specified fluid for that transfer case is AutoTrak II, which is blue in color. How dark is the T/C fluid, and does it look more like transmission fluid (reddish) or....
T/C drain and fill takes just under 2 qts.
Good call, I forgot.
Saucy_Walnuts
Saucy_Walnuts
NW Oklahoma
It's a dark blackish Grey. And I was going to change it out anyway because I have no idea when the last time it was serviced.
I did do that last night after logging off. I jacked it up and spun the bearings and checked for play. None was to be found
This is why you need to address the "known" and do the "blue fluid" change and deal with a known problem.
The noise can travel inside the cab and could be from the rear. If you have no idea how old the diffs and transfer case fluids are, change them.
Also, when I talked about a 2wd drive in a straight line at 25-40 mph and turn left and right to listen for increased noises, I mean slight turns. Like a quick dodge of a pothole in the road. Not a 90* turn but a slight steering wheel move from 10 to 2 o'clock. As you turn left you will throw the front weight to the right front and that can make the right front bearing make more noise. Same aspect as you would turn right and load the left front. You can still have straight down the road noise from front bearings but the right/left slight turn can help pinpoint the problem side.
If noise is coming from rear, get rear tires off ground and in neutral, check for in and out play, up and down play and noise when roll them. Look for axle fluid leaks, too.
How about the front differential? My truck is AWD, but I had a growl in the front end, and when the mechanic put it on the lift with a person inside operating the shifter and throttle, the mechanic used his stethoscope to pinpoint the source of the issue -> front differential was shot.
Coveman
Saucy_Walnuts
Saucy_Walnuts
NW Oklahoma
I will try that. I will be servicing front and rear diffs. Along with the Tcase this weekend. When I looked I did not notice any wetness/dampness on front or rear diffs. There was a slight wetness on the Tcase but it was full of fluid. I will check for play in the rear end when I service them.
Saucy_Walnuts
Saucy_Walnuts
NW Oklahoma
I will have to see about that and may need to do that. I believe I have a mechanics stethoscope somewhere
Saucy_Walnuts
Saucy_Walnuts
NW Oklahoma
On my ‘99 my t case started making noise and turned out to be the pump shaft rubbing on the tcase housing. They make parts to prevent the pump shaft from rubbing through the soft magnesium case like.. https://www.amazon.com/TIKSCIENCE-Transfer-BRNY4080-78889-482460/dp/B095LQQCRV or alternatively some rebuilders use a harder aluminum case instead.
I did read about that being a issue. I will most definitely look into it. I might as well rebuild it while I've got it apart
Saucy_Walnuts
Saucy_Walnuts
NW Oklahoma
Well I think I found the noise. I probably need to rebuild the front diff or find a good used one.
That is nasty looking and could be close to normal if it was the first fluid change but if is still rounding off sharp edges this many miles down the road and fluid is original, I would clean it out completely and add new fluid and drive it to see what happens and if does quiet down, then change fluid again at 5k to 10k miles.
Plus, make sure you do the rear diff and the transfer case.
Capybarbro
