Tranny Cooler Fan??
Rivieraracing
Any of you guys have an electric fan on your tranny cooler? If so what did you go with and did you notice a difference? I'm pondering on getting one for mine as well as installing electric fans after I get my Black Bear tune but wanted some input from others!
rich5368
Cheyenne, WY
I've never heard of it being done, but I can't imagine it being needed. Even pulling heavy loads my tranny stays pretty cool.
WoldD90
Off Road Addict
Atlanta, GA
I can see adding it if you tow heavy loads, and it is switchable. But, if you are looking for performance, I do not see the need.
I installed dual electric fans on my 6.0 Yukon, no real changes in temp or power. My tranny cooler is stacked with my radiator and AC cooler.
The only noticeable difference is when it is hot and the AC is on... I do not hear or feel the pull of the fan clutch.
On my Land Rover Defender, I installed electric fans and it made a noticeable difference, but that is on a lower HP V8.
BOSS
The People's A D M I N
Dallas
There are some coolers that already have the fan, Permacool has some. No experience with them and haven't heard of anyone running one yet - I personally plan on doing one soon as I know my tranny runs hotter after the build out I did on it.
B
Rivieraracing
Rivieraracing
I'm thinking about it for when I tow my toy hauler, it use to warm up alot when pulling certain hills with the trailer loaded as well as the coolant temp but since I got a new waterpump, flushed the radiator out real good, and I even think the CAI and corsa exhaust help a bit, it barely warmed up on those same hills I just recently pulled with my trailer last week!! I'm going to do the electric fan conversion when I get my Black Bear tune done but was still thinking about putting a fan on the cooler just for that added help in keep my transmission cooler!! Anybody else?
---------- Post added at 07:34 PM ---------- Previous post was at 07:32 PM ----------
B
Yeah, I have seen those, that's what gave me the idea!! Just hoping someone on here knows if they truly help out much!
Rivieraracing
Rivieraracing
Soon I'm gonna find out just how useful one would be, bought the harness I'm gonna use for it today, just about to order the fan! Soon very soon!!
BOSS
Dallas
Hey man, I just bought a B&M stacked plate one with a fan...measurements say it will fit, noot sure yet tho :)
b
Rivieraracing
Rivieraracing
Nice, do you know the measurements of the cooler, mine is a 11X11 and it fits perfectly!! Lots of room!
chistoso
Arizona
I had one in my Tahoe and I had problems cause it conflicted with the speeds on the e-fans, either the e-fans would push or pull the tranny fan or vice versa. and there was no noticeable gain in having it. What I did is hook it up to a relay and a switch to turn it on manually when the tranny would get hot but it never did even under load uphill with 7-8 people in the truck and a 30' MasterCraft boat. I don't even remember turning it on but once or twice that's it.. I can see it being useful with a mechanical clutch fan where you would be idling and no air being forced thru the cooler and you would want more...
Rivieraracing
Rivieraracing
I'm gonna hook it up to a relay and switch as well, and I was curious on how it would work with electric fans! Might be a bit til I get the electric fans so it might be useful now, thanks for your input Chistoso!!
And Boss, you will have no problem making that fit, like i said lots of room!!
BOSS
Dallas
Good info Jer, I think I'll switch mine too...but it's a good size cooler over stock and stacked plate design which are very efficient. My pair of 16" efans should pull plenty of air through all the exchangers.
So chist I'm guessing due to the room behind the grill, the tranny cooler fan was mounted closer to the grill....so are you saying your tranny fan was set to push, and the efans were pulling? Sounds like that would work?
B
chistoso
Arizona
The efans are designed to pull air so I had the tranny cooler fan to push but it got interesting when the efans were pulling in more air than the tranny fan could push, one would force the other which led me to believe that if the efans could pull more than the tranny fan could push, it rendered it useless.. Make sense?
Rivieraracing
Rivieraracing
Do you remember if you tranny cooler was tight to the radiator/condenser or was there gap? You got me thinking now, I might have to experiement with my placement if I notice the same thing!!
chistoso
Arizona
None of the fans on the aftermarke fit so I borrowed one from a car, cant remember which but it was 13" diameter, 2 speed and slim enough where it cleared the grille and cooler by a fraction of an inch. The cooler was right against the Radiator/condenser. It came off a Cadillac Catera IRRC.
Rivieraracing
Rivieraracing
Thanks for the info Chist, I'm gonna have to experiement a bit when I do mine, never thought about the fact that the electric fans would over power it! Did you hook the fan up to use both speeds?
chistoso
Arizona
High speed only and still over powered by the efans. Even standing still the efans pulled the cooler fan fins to spin.
BOSS
Dallas
Yup, I'm thinking it was efficient that way?
That tranny fan would take care of the initial push (and drag) through both the tranny cooler and the ac exchanger. Then the efan would pull hard against that air, and of course through the parts of the main radiator.
B
CKendrick
