efan install problem
bsims3996
alabama
i hooked up my efans today, but when i went to crank it up it wouldn't stay running,and the check engine light came on. when i would disconnect the power from the BB harness it would stay running and the engine light would go off. i triple checked all my connections and didn't see anything wrong. now with the power off the harness the battery voltage is jumping back and forth from 9-14volts. any ideas on whats wrong
the code its showing is 0641. does anyone know what this means?
sorry, i meant to put this in 00-06, if someone can move it , thanks , I don't know how
chistoso
Arizona
PM Justin or Jenna over at Blackbear. They might know.. Sounds like there may be a bad connection or a relay problem to me..
Justin tuned mine and he turned on the pins and the fans and everything is running great minus I'm going with one of his harnesses here in a couple of days..
bsims3996
bsims3996
alabama
i just put my factory pcm back in and everything is fine. i don't kknow what happened i followed the harness directions perfectly.
chistoso
Arizona
So everything is functioning right? You had a different PCM in it?
bsims3996
bsims3996
alabama
it is now with the factory pcm. i had the black bear pcm in, what happened is when i was reconnecting the green plug on the pcm the pin on the harness was bent a little and pushed the pin into the pcm. thats my luck (just like getting outbid on a OEM fan and harness on ebay)haha. i pulled the pin back out, don't know if it will work but Jenna is checking to see if the pin on the pcm can be replaced. (she thinks it can, but with my luck the whole thing is F@#ked up
BOSS
The People's A D M I N
Dallas
Don't hate the player....
B
xodave
North los Angeles
I am really interested in putting E fans in my 02 Kon. Have you guys gained any fuel mileage with the electric fans....How much?
glazar
