What happened?
Modded
Modded
That Guy
The Hoe92,
A 295 series tire may work, but I would rather e safe than sorry, despite all this BS rubbing. And you are def. right when you said once the Tahoe is low, i can not go back up, just lower.:Handshake: Also it only rubs the wheel liners and washer fluid tank, nothing else to my knowledge.
Conor,
Like I said to TheHoe, I have fallen in love with its current stance and am only buying the Bell struts to go .5" lower to do away with Cali Stance. It should not rub anymore than it already does because .5" more is really not much.
NastyGM,
Looks like me and you are in the same rub boat, and I did not feel you were thread jacking, just adding more info.
BogeyBoy82
The Woodlands, TX
whoever bought your old wheels must be some kinda schmuck.....oh wait lol. This thing looks slick man. I think next on your list needs to be a bangin stereo.
thehoe92
fo sho
The916
not sure with the NNBS but check the rear passenger inner fender towards the door frame
my A/C lines are run right there and I rubbed through the insulation and bare pipe is showing so keep an eye on that
also something I've learned, every week or so either jack your truck up or take the wheels off and check all the fenders to see if you have accumulated any more rubbing
you would rather catch it early than rollin down the road and wonder what just flew off or why something doesn't work now
Modded
Modded
That Guy
Haha you have a real slick set too, now your Tahoe looks like my Tahoes twin haha. I want a stereo, just not sure how I want to do it though.
Yeah I agree with you on that TheHoe92. I think I am just about good out back, the a/c lines in these are non insulated and look to have cleared the tires by around an inch. The top shock bolts clear the tires by about .75" too or I would have had to flip them.
Only thing really bugging me rubbing wise is the rubbing on the parking brake cable insulation and the washer fluid tank.:emotions122:
thehoe92
fo sho
The916
mine rubs on the washer fluid tank but it hasn't rubbed through the plastic, its just minor
as for the parking brake, be careful on that one because I think blizzard is getting close to snapping his
mine rubbed through the plastic on like a dime sized section so now its exposed but after cranking the torsions a little I don't rub on full lock
what are your measurements?
Modded
Modded
That Guy
My measurement are 34.25" out back, and about 35" up front.
The front needs .75" more drop, the tire are 33.2" diameter wise, so I knew I would not want to be anything closer than .75" close to the tire to avoid fender rubbing due to those wide ass tires.
thehoe92
fo sho
The916
damn!
I guess I was lucky because my front was lower than the back so I was able to lift it and level it out so that way I didn't have to keep rubbing
..but you have to go lower
Modded
Modded
That Guy
Yeah and it sucks because I already rub bad enough, I'm gonna see if I can zip tie the parking brake cable as far back as possibly w/o snapping the the zip tie.
Modded
Modded
That Guy
Update:
Got some Belltech struts in to get rid of the .5" cali lean, ended up lowering it .6" in the front. Rubs jut about the same as before except now its pretty much on the parking brake insualting, and rubs the top of the fenders when going over mediocre dips.
Driver side fenders are at 34.4", while the passenger side ones are at 34.25".
Since the tire is 33.2" there is next to no fender gap, looks hot!
NASTY GM
Nor Cal
Update:
Just like mine :High 5:
Modded
Modded
That Guy
So you have the same fender scrape over dips like me I assume?
If so, has it messed up anything, don't want to bend the fender, mess up the paint, or the tire.
Modded
Modded
That Guy
I will take pics either Sunday or Monday and upload them.
NASTY GM
Nor Cal
Are you talking about the inside (fenderwell) of the fender? That's where I scrape. I have worn off the insulation of my e-brake cable and I rub the tank, even with the hole I cut out. All the more reason I'm probably going to bag mine :disgust:
Modded
Modded
That Guy
Yeah thats where I scrape too, whats offset does your have?
I zip tied the cable and the washer fluid tank back so it does not rub on them unless the turn has uneven road.
Since you already cut the tank, the only thing you should be rubbing on is the parking brake cable right?
mlwald79
looks good. what wheels did you get?
Modded
Modded
That Guy
Fortune Alloys from JR's Custom Auto over in Irving.
Modded
Modded
That Guy
Well i'm back on jack stands again for a few days, who would like to gueess what i'm doing this time?
vsaravia
