Ox Locker in GMT900 with 3.42 gears?
07CLASSIC
Has anybody installed an Ox Locker in an 07-14 Tahoe, or other GMT900 model, with 3.42 gears? I have researched it a bit and was told at some point that the diff housing has a unique shape, especially in the 'classic' models, that doesn't allow for this locker, or makes install very difficult?
Any info on this matter is appreciated.
Thanks.
(Thread transferred from TahoeForum)
strutaeng
Dallas, Texas
Have you called the manufacturer? Looks like they are in Florida.
The website just differentiates between 28 spline (older 10 bolt axle) and 30 spline. Doesn't mention anything else.
I don't have any experience with OX Lockers, but have always thought they are cool. I wish they made them on the GM 14 bolt. Not sure why don't make that model because that's a super popular axle with the off road crowd. That's not here nor there tho.
Please keep us updated on what you go with.
07CLASSIC
I have not. I will look into that.
Yes, from all my research, I really like the concept of the Ox over all the rest - and I prefer the idea of the manual lever option as opposed to the E or Air version. (Pretty sure they offer all 3 now).
Turn it on/off when you choose, no E or Air to ever fail at the worst time.
I have read that the manual lever cable needs to be adjusted from time to time, but that's something you could do on the trail in a pinch, I believe, and if all else fails, you have the option of manually screwing a bolt into the diff to activate the locker in a worst case scenario.
Love it, but it's $$$ and I'm still unsure if they can be installed on my 07 Classic diff. I'll try and contact them and update here.
hillstrubl
I had an Ox locker in the front of my '98 TJ Wrangler, it was fantastic. Never bound up, no special fluids, etc. Having said that, the rear of a (assuming) street-going tahoe seems like an odd application for it. I'd go gear-based limited slip over anything in this, eg Eaton Detroit Trutrac. (Are you sure you don't already have the factory G80 Limited slip diff?)
Charlie207
LFOD, New Hampshire
Did OP say he was placing it in the rear diff? Seems like the front would be the better location with the G80 already in the back, assuming it had that option.
hillstrubl
Looking back no, I guess I just assumed. Agreed that front would be a better application, but even then, I'd say LSD for there too especially with "auto" 4wd being a thing on these.
Charlie207
LFOD, New Hampshire
I wish I knew more about the front diff (or any diff, really) specs. and interchangability, but if there was a G80 that fit in the front case it probably would have already been written about.
Thanks.
what is your build so far? lift? bigger tires? otherwise there is really no point in trying to fit a controllable locker it likely won't provide any real benefit.
and if you do have a lift and bigger tires 3.42 is probably the minimum to start with.
around here the trails are pretty tight and are jeep trails, trying to fit a suv thru is likely to end with body damage.
07CLASSIC
It's 2wd. Yes, it's on the streets mostly, that's part of the reason I prefer the manual ability to turn it on/off when needed. I do mild off-roading, never tight forest trails or mud or rocks, usually to take the dogs to a place they can run and explore. Sometimes I just explore a little, without seeking mud, and do some hill climbing.
It's actually handled a lot more in 2wd than many might assume, I believe due to the extra body weight over the rear wheels improving traction, etc. I did get stuck once when I ventured into some mud that wasn't visible below the grass line. That's the kinda issue that would've been quickly solved by a locker, in my case, as the other driving wheel was on dry solid ground.
I've looked into just trading for a 4wd vehicle, but it's just not practical for my situation. This would enhance the capabilities of my current Tahoe and would also help sometimes on icy streets.
No G80.
07CLASSIC
I did speak to a tech at Ox Locker in Florida and they weren't aware of any issues with my year model. They did direct me to East Coast Gear Supply for further inquiry. I will look them up online and speak to them soon and will update further if needed.
07CLASSIC
Rear diff, 2wd, no G80.
07CLASSIC
Yes, if I'd gone the 4wd route, I'd definitely opt for 3.73's at a minimum. This would be an occasional off-road enhancement for my 2wd. It is what it is for now.
the eaton tru trac should be fine in almost all cases, it's bullet proof that's for sure. (I haven't broke one yet lol) but have broken plenty of g80's
but for a definitive answer you might try reaching out to filthy motorsports I have had there page saved forever for referencing what can be used and what is available
based on the axle/gearing etc they show the OX as a option for "some"
07CLASSIC
the eaton tru trac should be fine in almost all cases, it's bullet proof that's for sure. (I haven't broke on yet lol) but have broken plenty of g80's
Hmm. I was pretty sure I'd thoroughly checked out the Eaton Tru Trac, but I was thinking it was an auto-locker, which I didn't want for certain situations. Now that I see it is NOT, and is a unique limited slip, I may need to take another look at it. Thanks.
I'll def check out Filthy Motorsports.
I referenced them because of the information there page shows and usually video's on various products with a in-depth look at how they work
strutaeng
Dallas, Texas
I think a selectable locker is better for more aggressive off-road use, like a dedicated (or not) trail rig. Why? Because it locks the rear axles so they spin 1:1.
The LSD have some slip between the axles, which is fine daily driving and some mild off/moderate off-road use.
I forget what the Detroit Truetrac is, but I want to say it's an LSD(?) There's different types of LSD mechanism and that particular one is a "Thorsen"-type LSD. The Thorsen differential require you to apply the brakes momentarily if one wheel is in the air to engage, otherwise if behaves like an open differential until you force one wheel to stop.
Probably doesn't matter OP, but you may want look into the differences.
This video I think covers that:
07CLASSIC
I had forgotten about the Torsen design, I've seen videos in the past about how it's used on military vehicles and read about how unique it is. I'm def considering this option more now. We'll see. Don't mind the idea of it always working on its own and it doesn't hurt that it's a good bit cheaper than the Ox as well.
07CLASSIC
Yes, you're right about the Torsen/Thorsen design. That's pretty interesting. I'm researching the pros and cons of both now. Thanks for the vid.
strutaeng
Dallas, Texas
Yes. Pretty interesting indeed.
Honestly, they all have pros and cons. On the selectable locker where they lock 1:1, you can't really steer or turn, because both wheels are turning at the same rate. Going around a corner, the wheels would bind if they have good traction.
Similar to the guys that would weld their spider gears on a daily driver. Not sure why anyone would do that for a daily driver. Driving around a parking lot you have a lot of tire screeching. I guess if you are really poor and have a welder, then everything looks like a nail...-type of thing?
I'm sure you be happy with the Thorsen LSD for your application. :cool:
07CLASSIC
@strutaeng
That's an excellent video. Thoroughly informative yet not too long and drawn out. I've seen it before years ago but forgot how good it was. Looking into a TrueTrac at this point and possibly re-gearing to 3.73's.
I've heard/read many say that's a pointless re-gear - if you're gonna do it, might as well go up to at least a 4.10 - but I think for my application it'll be well worth it.
It's a 2wd DD that just needs a little traction enhancement and some more oomph for the local hills around town. 3.42's are pretty disappointing, I can't believe they're putting even more anemic gearing than that in many trucks today. 3.23's, 3.08's, etc.
There are a number of other ways they could improve MPG without robbing a truck's torque output.
Bob LaFord
