For those that put stickers on the hvac controls
Fefanatic
Did you scrape the old labels off or just put the new over the damaged ones?
Big Mama
Virginia
I put the stickers over it. At night it doesn’t look great but it wasn’t a big deal to me.
If there is a lot of wear on the original buttons, you can scrape them clean so the blemish doesn't bleed through at night.
Mine weren't so bad, we put the stickers right on top and they've been on almost 8 years now.
my preference was to replace the control, didn't like the look of the stickers, a new one does have to be programmed (or should be programmed) for proper operation
in my case it made the rear only make heat if it was set to 90, put it on 89 and it would go cold, programming fixed it.
opfor2
Riverside County, CA
What years need to be programmed? I replaced my manual controls on my 2011 and they seem to work properly.
I am not sure the same control is used in multiple vehicles so it could depend on what it was programmed for out of the box or what vehicle it came out of if used.
mine was looking a 3rd headliner environmental sensor that my vehicle did not have (causing a error).
I spent a good amount of time troubleshooting what was causing the problem and in the end it was the calibration file on the controller not being set for my vin
j91z28d1
I just put stickers over mine. they look fine in the day and little dark at night, but no issues for me.
I noticed the recirculate sticker is wearing out haha. gotta find where I put the 2nd set that came in the pack. wife hits it every time she gets in. this truck sucks in more outside smells than any other thing I've driven and acts like being in recirculate is a crime. I can tell when the Ford truck 3 cars ahead on the highway is missing and fouled the cats haha.
homesick
The Best Me I Can Be
Navy Air Force
Cabin air filter?
joe
j91z28d1
Cabin air filter?
joe
I have one in it, it's they only stop debris not really fumes?
it's funny, we got a 3d printer to play with and the kid wanted a air vent propeller thingy. clips in the vent and spins with air. as you speed up to highway speeds you can see it start spinning from the extra air coming in. The recirculate flap seems to move correctly, and it is worse when not in recirculate. but it's kinda wild haha. never noticed it in any other car.
homesick
Navy Air Force
I'm just scatter shooting here, but maybe a blast of Lysol or some scented spray at the air intake?
joe
Foggy
KS
You can get a replacement filter that has the charcoal in it that does smells, etc
I did the retrofit to put a filter in my Yukon. I found the filter on RA
I have used the stickers on 2 GMT900’s and both look perfect day and night. The trick is to scrape the centers off, the part that’s under the symbol areas that show through when lit and leave the black around the outer edges so that part doesn’t bleed through when lit. My Silverado control is over $400 new, not sure what the Tahoe would have been but it’t pretty silly to me to replace them when an hour of work and $10 worth of stickers makes them look new. Plus the new ones will eventually wear off. The vinyl stickers should last longer. ****** GM design on them. Use tweezers to place the stickers for accuracy. They can be repositioned until perfect. Just pay attention to the reveals.
j91z28d1
looks very nice.
my recirculation button is already showing wear. I have the 2nd set around here somewhere. I might try removing the black center next time.
worleytrev93
