2015 Tahoe LTZ - intermittent brake assist loss at low revs - vacuum pump?? - SOLVED
petethepug
Michael
SoCal
Low RPM means highest vacuum. If you have a vacuum hose coming off the brake booster, replace it. They deteriorate over time and can collapse on themselves under high vacuum.
Essentially slow speed, high vacuum, hose collapses on itself and then zero vacuum and hard pedal until hose unsticks.
2015TahoePPV
NC
apparently when its running as a 4cy, the vacuum is low enough that the test engineers didn't like the brake feel when they simulated panic stops from a normal cruise speed, so the external pump was added. There's a lot of different conditions for the 4 cylinder mode to activate, but thankfully I've eliminated that problem.
2015LTZ
2015LTZ
I have a 2016 burb. I had this exact same issue. Hard brake pedal press. It would happen when backing up to park and drive throughs. I replaced the vacuum pump (mine as well replace the belt) and this fixed it. At one point I had a bad wheel bearing too and thought that was causing some sort of ABS confusion. Nope that didn’t fix it. It’s most likely your vacuum pump. With this being a critical component, in my opinion, get a good one. Go with a GM replacement. You can tell if you have the upgraded fixed component because the vains are bigger on the new one.
the symptoms would be a loss of braking at low rpm or having to press the pedal harder than usual or even loss of power brakes period, or a "service ***" message in the cluster.
the abs engaging at low speed or just before coming to a complete stop would likely indicate one of the sensors is not reading the same as the rest so the brake module thinks a wheel is slipping so it engages the abs pump to attempt to stop the vehicle without skidding (even though you may be moving slowly). the result is pulsing of the brake pedal and loss of brake control for a moment and then a sudden complete stop (or any combination of), you may hear a weird noise associated with it as well which is the abs pump engaging.
as far as checking the abs sensors, if there is no code or abs light on then you need a scanner to see live data when this is happening, the scanner will show all 4 of abs wheel speed readings and one may show 0 and the other 3 4mph or something to that effect. sometimes when this happens it's not a enough of a error to throw a code or light up the abs light but still causes a driveability problem.
if it is a abs sensor it's usually a front one and those are located on the front wheel hubs, behind the brakes.
hence why it is wise to check the hubs because when the hubs wear out it causes the abs sensor to go goofy because the sensor inside the hub is affected by the hub bearing being worn out.
the wheel hub is what has the lug bolts and the bearing that lets the wheels spin, the abs sensor is in a hole in the back of the hub with a single bolt holding it in and a wire that snakes up the upper control arm and attaches to the vehicle harness.
the sensor is magnetic and reads a corresponding magnet inside the hub and when it spins this is how it determines the wheel speed
there really is nothing visual to check, if one was unplugged or something you would get a abs light. some people say they can get rusty and that might be a cause, but if you have rust inside the hub then it's probably time for new ones anyway because bearings and rust do not mix well
thanks everyone for the inputs. got the vacuum pump replaced from the dealer. the problem has been solved. its been almost 2 weeks now and no brake-related issues. in fact the brakes feel much better.
2015LTZ
2015LTZ
any idea about the part number for this hose?
petethepug
Michael
SoCal
Double check compatibility. R/A is outta stock. P # 42477121
Just noticed in previous post he replaced vacuum pump. I guess that was what the part # request was for :cool:
how much did they charge? or was it covered by gm?
2015LTZ
2015LTZ
i am based in Riyadh, Saudi Arabia. I went to the GM dealer I bought the car from. It was not covered by GM (should it be??). I paid USD 406 for parts and labor. It was a 45 minute job.
I would assume a dealer would know if the pump was under special coverage or not, if there was no code then they probably wouldn't have covered anything anyway
2015LTZ
2015LTZ
nope, no codes.
Hodmjstone
