Looking for 1989 Cutlass Calais parts
grouch
I'm getting so far into this car, I will probably keep it. It's a sneaky little dickens and is simple enough it's refreshing to work on. Mechanically, it's in really good shape. Bodywise, it is RUST FREE. there is one little spot where something bumped the body and some surface rust there. The car has Ziebart plugs so I'm sure it was rust proofed when new.
I need the following;
Hood
Driver front fender
headlight assembly.
The parts must come from a Calais as a Cierra might look similar, it isn't. It's a slightly larger car. My current headlight came from one and the previous owner had to break them to get them to fit. I can get fiberglass hoods for $700 to $1400, but want to keep the stock look to keep the sleeper function.
grouch
grouch
Played around on the site and found several promising leads but the best ones are both 320 miles away. Opposite of each other too. I did find some that might have parts, just not listed, closer.
grouch
grouch
I played around and got better results but most are well over 300 road miles away. I also have a conversation started giving me a gmail address to contact, but the poster has zero posts on the forums. He may or may not be a scammer. I've dealt with those before.
grouch
grouch
You could always have the smaller parts shipped.
The one part I really need is a hood. Yes, it can be shipped, but there's a risk of damage. I've got to straighten other things out before I need to replace the hood. I did find a pair of fenders about 110 miles from my house. They have a used factory and an aftermarket unit. $72 for the oem off a car and $25 for an aftermarket. I plan to call them once the car is running again to see what else they have.
Durobans
