ReadyLift for 2016 Yukon SLT XL
maidi3000
Good morning...
Would you advice me plz about this kit..
The price, brand, company, type..etc
Stock front (non-mag)/B4600 rear suspensions and stock wheels (265/65 R18) Is it ok? Lifting (hight & level),wheel/rim size and riding? I like the shape of face lift but not too much hight (like Sierra)
I saw some saying Yukon XL 1500 and some saying Yukon XL and others Yukon Base when I choose, what is the differences?
Thank you all
Trey Hardy
Good morning...
Thank you all
You can buy the same spacers separately on Amazon and eBay for around 100$ if not cheaper. No need to spend 350$ if you can spend 100$ on the same stuff..
Also the Tahoe Yukon and Escalade models of that 07-18 body style use the same suspension
Same for the front anything from a 07-18 Silverado sierra tahoe Yukon Escalade avalanche will work as the front suspension is all the same
Instead of both upper and lower front spacers I’d just opt for a 2” LOWER strut spacer as it’s much quicker and easier to install without having to remove the strut from the truck
Trey Hardy
Good morning...
Thank you all
Trey Hardy
60$ vs 330$ no real difference in the quality and I’ve ran that brand for years without any issues at all.
I think I did eventually swap out the bolts for some stronger grade 8 zinc plated ones but that was about it
M
maidi3000
Thank you for tha value info..
2 inches front + 1 inch rear will let me to fit large size wheels?? Or better to take the 3 inches front+ 2 rear?
From where to get thegrade 8 zinc bolts? Would you plz provide me a link for a strong good brand
Trey Hardy
The bolts included are fine unless you plan to really baja it then you can get the bolts from ace Lowe’s Home Depot etc
And I cleared 20x12 on the 2” leveling kit with 285s
I also cleared 24x10s on 33/12.50s with a 3”
What size wheel are you trying to step up to? I cleared the x12 wides on stock 275s with no lift at all without scrubbing
Trey Hardy
Also that lower 2” leveling kit and rear spring spacer is a breeze to install don’t let no shop charge you a arm and a leg cause it only takes 30 minutes
M
maidi3000
I am thinking 33” but not yet in the current time..
M
maidi3000
Thank you..I am always working at home DIY
Trey Hardy
33s should be fine unless you get some serious offset like x12 or x14” wide wheels then you’ll have to bring it up to 3” or so and do some other stuff like differential drop and control arms to accommodate
TommyGunz4498
Good evening. Any advice on putting a 2.5 inch leveling kit on a 2024 Yukon Denali with Maganaride? Will it change the ride up with also adding 305/45r22 Toyo Open Country A/T III tires to my stock 22’s? I hear that if you alter the suspension in any way you change up the ride drastically, but I see people doing it all the time especially this company called Auto Plex Customs out of TX.
Tupapi
