Solved. New fuel pump, hard start.
Mcneils10
Hello everyone.
New here. I recently bought a 09 yukon denali with a blown up 6.2, I rebuilt it and but it back in. Now I'm a month down the road and I had to replace the pump due to rust at the assembly. After I replaced it I still had about 3-5 gallons of fuel in the tank, I tried to start and it started but took a few seconds probably around 5-10 seconds of cranking before it fired. I filled it to a half tank no issues but still take a few seconds of cranking to start or I have to try to start it a few times before it will fire. Any one know what could be going on? I'm checking the pressure in the morning.
M
Mcneils10
I'll talk to my brother who tunes cars about the correlation sensor. Thank you for the advice.
j91z28d1
was it an oem pump?
I put a napa pump in my 96 and it was hard starting after that. I believe it wasn't holding fuel pressure correctly when it was off. if I clicked the key forward and paused for a second for it to build pressure. it would fire off cleanly every time like normal, if I didn't it would crank a few seconds longer and stumble a bit after the flare and then clean up.
I've just seen that newer gm now with the push button start will activate the fuel pump for a few seconds when you open the door to prime the system before cranking. I found that interesting.
petethepug
Michael
SoCal
Welcome from SoCal. Nice pull on the L9H in the Denali. Pull the charcoal emission canister and verify it’s not spilling carbon pellets into the field system.
Only use OEM f/p or Bosch, preferably with the lifetime warranty. Best prices on rockauto and parts geek. Generic f/p can have you chasing ghosts, intermittent ones at that.
Check your crank position sensor. I learned the hard way they fail and cause hard starts without sending a code.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum from Oregon.
You can edit thread title and add Solved, for others who read thread.
petethepug
Michael
SoCal
Going to be doing my fuel pump soon. Anything else I should check or change while I have the tank out?
If you suspect a rusty top on your fuel tank, have a new lock ring handy just in case. Also, IIRC an evap line goes OVER the crossmember; be sure not to squish it by having it under the xmember.
petethepug
Michael
SoCal
LOL empty gas tanks are much nicer to work on. 09-14 owners, Don’t have e85 in tank when you swap pumps. If you have to reset the fuel trim, it ONLY calibrates on petroleum, not e85.
petethepug
Michael
SoCal
Touché
petethepug
Michael
SoCal
4 would turn it into a Black Widow. Not enough lateral stability. You’d really have to block out the front wheels because the parking brake is only in the rear.
Ah ¢rap! Looks like a scam site. It’s on the shunpuss website, not Costco. I should of caught that
77mercury77
Funny that you post the advert of the lift. I was planning on backing it up onto ramps to be able to pull out the tank. It think i only need to raise the truck about 8-10 inches to be able to drag the tank free past the lowest points. My other option is to jack the truck up from the rear (heh) and put the rear axel on jack stands. I have never lifted the truck from the rear diff; looks like that would damage the housing and the rear diff cover. If i have to do this because the ramps wont do where do i put the puck of a 3 ton floor jack on the differential? I got scrap 4x4s and 2x4s for cushion but i dont see a good location for a safe and clean lift point on the diff.
Tupapi
