Be Careful When Replacing Front Strut/Shocks
2Cool2Fool
I decided to replace both from struts on my 2016 Yukon. This is the third time I've replaced these combination spring/shock assemblies on Yukons or Tahoes, but I ran into a problem that hopefully will prevent you from having the same problem I had.
I bought a pair of after-market (OEM replacement 'QuickStruts) from NAPA - because I couldn't find the combination units available online from Delco or GM. The first one installed with no problem. However, the second unit had a manufacturing defect that I didn't discover until I tried to install it.
Here's what I learned (the hard way): One of the top mounting studs MUST perfectly align with the center of the lower shock mounts. The attached picture doesn't show it exactly because of the perspective of the photo - but if those two points points don't light up closely (+/- a couple of degrees), the installation will be all but impossible. So when you buy your new strut assemblies - open each box of each and check the alignment.
When I called my local NAPA store, fortunately, they had two of the same assemblies in stock - and they sent a driver to my house on Saturday with both units - one of which was fine - and swapped it for the defective unit.
I hope this saves someone a significant hassle.
ReaperHWK
Just FYI as well GM doesn’t sell that as a unit. You need to buy the shock separately if you want OEM and remove the shock by compressing the spring.
Since the springs are pretty big you can fit 2 sets of spring compressors on there(meaning 4 of them) and it will be pretty safe. Done it before. Even if 3 failed it would probably hold long enough for you scream the lords name in vain and dive behind a concrete wall.
B-train
Hello,
What brand struts do you have? My 2015 Denali has a leaking front strut
I would recommend just going to an online GM parts store and ordering per your vin number. Replace in pairs the strut, and mount if it seems bad - I've never replaced a mount on mine with over 160K on it though.
Your other option is car-part.com for low mileage auto salvaged items. If you don't want to keep the autoride system up front, you can look for front struts from just about any GM truck or SUV and swap them out. Then install the resistors to keep the light off. This is your cheapest option, but you can also get the exact struts you have now to plug and play.
Also to note: 2007 - 2020 are all the same. The parts catalog will say differently, but it's just a change due to a new model from 2015 on. I put 2019 struts with 40k on them in my 2008 Denali with the resistors, they fit perfectly and ride great.
The aftermarket stuff doesn't seem to hold up from my experience. I only stick with OEM now for the most part.
pretty sure the struts they used are not z55, which likely means the yukon does not require them, which means you can use a good quality shock like bilsteins which may outlast the vehicle
Rick10Tahoe
I did all OEM on 4 corners from Rock Auto. Couldn’t be happier. Z55 on a 2010 Tahoe LTZ. Used spring compressor on front. All went great except I first installed the bump stop upside down on one strut. I removed it and corrected my mistake after reviewing the install for the second strut. Highly recommend oem despite the costs.
Wilmington, NC
Anyone used to be able to purchase new and/or OEM Reman's from Arnotte Industries in Fl but now you have to go through a vendor/Reseller but either way, they are great to work with and I've refitted 3 of my SUVs over the years with their Reman and New GM products. They have never let me down and we love the OEM ride. You can still find their products from other vendors.
SaintMiles
I used my vin to order a strut assembly from gmparts dot com. They turned out to be wrong, the three upper bolts were the wrong pattern, wouldn't fit. I figured this out wiith my car on stands and the units removed. I decided to run to oriellys and got the monroes or whatever brand it was. Installation was no problem.
The ride was super soft and the front of the truck rode 2 inches higher than the stock setup. No Squats for me, thank you.
This is when I decided to get the stock part, I went onto rock auto, used my RPO codes and got the precise shocks(not whole assembly), all the replacement bushings and a decent spring compressor tool set, all of which still came out cheaper than the full assemblies.
I used my original springs and rebuilt the setup wit zero problems.
The ride is back to perfect and the height of the front is where it is supposed to be.
I returned the prebuilt ones. And highly recommend you avoid those.
PG01
Up here to the right
You could have just spun the shock to line up with the control arm….
jkhuntzinger
