will it fit?
Dan2002
my 2011 GMC yukon xl with the 5.3 emgine ,transmission is about to go out. and before it does i want to change it.
but i can only find a 2010 gmc yukon DENALI witch has a 6.2 engine, will that same trans fit my yukon? l
B-train
Yes it will fit. I think they are both 6 speeds. There is programming that will need to be done so the new one talks to your ECU
petethepug
Michael
SoCal
Yes, I think you scored. Both are 6SP 6L80 and pretty sure the 2010 & 2011 are compatible years software wise.
Let’s put the Bat signal up to see if @NickTransmissions can verify.
Taco
Late response but it definitely will
Fit and like B-train said gonna need a reprogram. My Chevy dealership came out and did one for me on a 2012 a month ago. Good luck.
NickTransmissions
Sin City
The transmission bench
Buy the replacement transmission then remove the pan then control body assembly (TEHCM, valve body, IMS, speed sensors/harness). Next, remove the control body assembly from your current transmission and install it onto the replacement. Perform a fast relearn on the replacement once you have filled it up.
Id also replace the torque converter with an upgraded one.
petethepug
Michael
SoCal
Just in time for the Veteran’s Day extended weekend. Thank you to those who have served.
brice715
