2013 no crank.
Tommy walton
New to forum. Can’t really find what I’m having trouble with searching here. So here goes.
Bought a non running ppv 2013 Tahoe, reasonably good condition. Here’s my issue.
The truck will not crank. Turn the key, nothing from starter.
Here’s what I’ve done:
New battery. Everything works as it should so far, only no crank. Pulled code pO316
Stored in ecu are dozens of other codes mostly all with sensor failure, tps, coolant, map etc. but recent code only the pO316. Replaced crank sensor against my better judgement and same issue. tested the starter on the truck with a jumper wire and it cranks the engine fine. I’ve checked/cleaned all grounds. No security light, I do not think vats is triggered. Tcm no codes. Neutral safety is in park position in scanner. While cranking, my manual gauge reads 70psi fuel pressure. No fire from coils. All fuses are good and installed. I’ve visually inspected the main harness, it looks ok and all connectors seem fine. Any suggestions on where to go next are appreciated.
Also, for any detectives here I found this report from I’m assuming when the trouble started with the Tahoe.
wjburken
Eastern Iowa
Have a couple questions:
1). Have you checked the starter relay to make sure it’s being pulled in?
2). You mentioned
Is this when you are jumping power directly to the starter?
T
Tommy walton
As far as fuel pressure i read it after cranking. Within 3 seconds, from my head under the wheel well to looking up. And no, the relay does not appear to be activating. Only 1 of the 4 prongs have 12v I’m assuming another is the neg trigger. Neither of the other two are 12v pos or neg but I can’t check during cranking without help. Which I hope to have soon.
Actually let me edit. The 70psi could have been from key cycling so much. I’ll confirm that also
wjburken
Eastern Iowa
Your fuel pressure is probably unrelated to the cranking of the engine as you have an electric fuel pump in the fuel tank that will pressure the fuel system when the key is put in the run position.
Might be worth swapping the starter relay with another one to see if you just have a bad relay.
T
Tommy walton
I have tried a few. And tested each one prior to installing. I think the issue is before the relay. I really need a complete wiring schematic
T
Tommy walton
I have tried a few. And tested each one prior to installing. I think the issue is before the relay. I really need a complete wiring schematic. Also shouldn’t the relay be directional? I’ve tried both positions but looking at the diagram on it shows the coil solid to be triggered then the switch side
wjburken
Eastern Iowa
Ebay Mike
Detroit MI
I am wondering with all the electrical items that have gone crazy at the same time if the vehicle does not have a wire shorted out somewhere that is making the whole system go haywire?
some places to check, but I would also check the that the ignition is reading the key position correctly. my 2012 has a ghost electrical handshake issue, if the battery is disconnected then of course re-connected it won't start (will not crank), has to be either disconnected again then go press the brake pedal, flip the light switch a couple times (dissipate electricity) and then go connect the battery again and she starts right up or when this happened once before I found a "security communication error" in the system with the tech2 (security light not on) cleared that error and it started right up.
Did you check the continuity within the main battery to starter wire and the battery to ground main wire with an Ohm meter? These two cables typically rot from the inside out, and while the exterior of these wires looks good, the copper within the wire has corroded. An Ohm meter will tell you quickly if these wires are an issue.
T
Tommy walton
No but I did apply 12v to the starter solenoid directly and it cranks very strong. But since I’m bypassing the system there is no ignition and possibly no injectors.
T
Tommy walton
I’m leaning toward a fryed Ecm or a bcm. I have not searched the harness thoroughly though but I plan to asap. Almost like ground is faulty. Although I did clean the grounds. I’m going start checking the harness.
mikez71
Someone here recently had a no start issue that was related to the relay.
Ended up being no ground to the relay socket, which ended up being a bad fusebox! (There was a bubble/break on the pc board)
You might test for voltages/ground at the relay terminals next.
There are some diagrams in that thread for the '07, which should be similar if not the same.. hopefully..
