Paint - Ceramic Coating - Question??
5StarCustmSolutns
Almost Heaven, WV
Been thinking about this for a couple years now. I've called 4 ceramic coating companies and 2 body shops to ask their thoughts about it, and have received 3 "yes, that should work but start in a small inconspicuous area first" answers.....and 3 "I don't know" answers. So I thought I would put it out here and see if someone with a more advanced comprehension of automotive paints would possibly offer some clarity? -or- better yet some opaqueness? o_O
Could a guy get a flat matte or satin-like finish by lightly wet sanding a gloss finish in a cross hatched pattern with 3000 or higher grit paper -or by- using a DA with light pressure and 5000 or higher grit paper....
-then-
thorough wash and rinse, proper dry
-then-
applying a matte finish ceramic coating to that no longer perfectly smooth and flat clearcoat??
Coveman
Yikes, I’d think that’d be a tremendous amount of work and cant imagine a consistent result. Is your clearcoat damaged?
Have you seen cars with the matte finish? The look great for about a second and then every fingerprint, smudge (people cant help themselves but to touch the finish, the cars at shows are roped off for this reason) and imperfection just jump out at you. I looked online at several manufactures of ceramic coating that claim you can coat a proper matte paint <but> results may not be what you’re hoping for. Also, the matte coatings put the durability at the bottom of the 1-7 year range which is no better than nu-finish.
I ceramic coated my burb and like the glossy result and protection, but the prep cleaning and claybaring these land yachts is no small feat, I cant imagine the work in hand sanding the beast to a matte finish.
5StarCustmSolutns
5StarCustmSolutns
Almost Heaven, WV
Thanks for the input.. With exception of one anomaly, my clear is still amazingly pristine considering my Av has been a work truck since day 1, 134k miles ago (157 now). Early summer I was washing w/wife's little 16 or 1900 psi SunJoe electric pressure washer and out of nowhere blew paint off the nose of my hood the size of a two basketballs?? Pristine navy blueish sheet metal underneath. NO rust, no impact, no explanation? No explanation other than a karma slapback for making fun of it/her when she bought it lol
I have seen matte/satiny finish in person up close once. Showroom floor, on a Merc Benz. (that was a lot more comma's and zeroes than the one we were buying that day lol) White....incredible finish. It wasn't roped off lol, but I wouldn't touch out of respect.
You just gave me a great image search! matte automotive paint flaws. I used to hang out in a custom shop that cycled 2-3 insurance repairs a week and always had some kind of crazy cool custom work goin on... Mostly that means I sanded a lot, but I listened a lot too.
That durability lifepsan with ceramic coating?? I know how the matte clear is sprayed, understand the chemical process. Gloss under magnification is smooth & flat. Flat, Matte, Satin has peaks and valleys, it's jagged. With Flat being rougher than matte then satin.... But the ceramic finish "allegedly" absorbs into those peaks and valleys and makes them more durable, harder. Helps hold shape, which w/o magnification would be helps keep the finish..... "allegedly" lol
Although I've never seen an automotive matte paint flaw in the finish. I have a hard time wrapping my head around it accenting the flaws?? Flat matte is the undisputed champ of hiding surface flaws....under the paint surface, and gloss makes them pop off the surface and slap you lol... But a finish flaw? I guess I just need to see it
Coveman
I cant imagine what it felt like to see your hood paint fly off like that, at least its a relatively easy panel to paint. Reminds me of the paint problems of the 80’s, if it didnt come off in chunks it just kinda dissolved on the horizontal surfaces.
You have a great looking rig, I like the plain white it looks cool without cooking you in the summertime. Whatever you wind up doing good luck!
strutaeng
Dallas, Texas
I do hobby woodworking (have used epoxies, conversion varnish and even 2k clears) and know probably more than the "average guy" on finishes. Also deal sometimes with high performance architectural coatings such as epoxy and 2k polyurethanes. And I've done a tiny bit of automotive refinishing, LoL.
General question: Are those flat/satin/mat finishes made like that from the factory? Like with flattening agents like they do in architectural finishes? Or are they "made" to look like that with sanding regular clearcoats? I know Summit Racing does sells their colors in Satin, but I'd figure that's for the guys doing some rat rod project. And I'm pretty sure they are single stage? I don't know anything about ceramic though.
IDK about wet sanding the OEM finishes as they are very thin, or at least they were. Probably a good idea to do it by hand? A small repair area is okay, but I'd be weary of burning through the clear and into the basecoat if doing the entire vehicle. Start on the lower fender/rocker areas and maybe the roof, then move into the more visible areas as you get a hang for the technique.
j91z28d1
sounds like a very bad idea. I cermic coated my c6 after tons of polishing. I don't believe cermic would stick to a roughed up paint at all, and it comes off pretty easily if it's not in a very well corrected surface. I cermic coated a polished smooth polycarbonate top and it didn't hold up at all in the sun. I'll have to repolish and install some ppf.
your best bet for a Matt finish would he matt ppf install. I've seen that done over white and it turns out very nice, plus protects the paint for 10 years. if you can wet sand and buff, you can't install ppf. Just watch some YouTube videos and buy some extra.
Reb03lb7
Matte ppf or wrap it
Don’t ruin good clear coat. You’ll regret this in the long run
My good friend owns a high end detail shop. He cringed harder than I’ve ever seen him when I showed him your question
Ceramic will also “fill in” the sanding marks leveling the highs and lows, to a point
He basically said this isn’t gonna work like you want it to
5StarCustmSolutns
5StarCustmSolutns
Almost Heaven, WV
Well.....I don't really know enough about the automotive paint industry to offer a technical answer? But....Flat Matte & Satin finishes have been available for years in rattle can and hobbyist form....and to best of my knowledge, when they first appeared in factory automotive finishes they weren't much more complex? But that was over a decade ago.
I consider this hobbyist level stuff: 2min long-
(WOW that POR matte black looks AWESOME) I have a drawer over here with 5 different "automotive finish" paint guns in it, and they all have a role, and I've used them all on different projects in last few years......but I am no pro when it comes to automotive paints!
At present, all non-gloss(non traditional) clearcoat finishes are a mixture of different types of clears and chemicals that change the way it flashes/dries/cures. It's a level of Alchemy that is over my head... Not over my head in comprehension, but in invention! How someone came up with this stuff baffles me!
This what I'm talking about: 4.5min-
and even that is 3yrs old lol....
As far as sanding the clear, that's standard procedure for repairing minor scuffs and scrapes. I scratched the ___ out of my old 2002 F150 FX4 when out testing it's off-road capaability about 15yrs ago. One of the guys with me that night had been doing auto body work for 20yrs. I didn't think it was too bad that night, but he knew better. He said bring it over Monday and I'll show you how to fix it. When I woke up the next morning, I about ____ in my boxers.....did I mention it was black.
Monday morning I rolled up at his shop and when I walked in shaking my head he just laughed, he knew how bad it was gonna look. He already had two buckets with water and sandpaper in them waiting for me. One 2000 one 2500 grit.
I was like NO WAY I'm sanding this. I'll have to the whole truck painted. He said "think if it like sheets of paper, there's 8-10 sheets of primer, over that is 15-20 sheets of base coat, and then 15-20 sheets of clear. 98% of those scratches only go about 5 sheets deep into the clear. Now, use a sponge behind your paper so you don't finger groove it to death, use even light pressure, and DONT sand any edges or body lines, you need to stop an inch or so away from them. Now get to sanding" About 5hrs later he brought me a bucket full of 3000 grit paper soaking in water, by closing time I finished all the wet sanding. My truck looked almost gray it was so dull. Went back Tuesday morning and he had a variable speed buffer, some rubbing compound, swirl mark remover, a polishing compound, and some high shine wax for black painted vehicles waiting on me. He showed me how to use the buffer, how to only use the 1/4 of the pad that was spinning off the surface and how to use big long sweeping strokes. By 6pm my truck looked like it had just rolled out of the spray booth.
I recently used some high end 3M Trizac 3000 and 5000 grit when restoring some headlights. It is incredible sanding paper. Has about a .1250 pad behind it. It's what I envisioned using, wet of course, on a DA if I were to attempt to pull off this DIY Flat/Matte Ceramic coated finish
5StarCustmSolutns
5StarCustmSolutns
Almost Heaven, WV
Thanks for asking somebody in the industry! And that's exactly what I asked the tech guys at the ceramic coating companies. Some claim that their polymer based Matte finish formula will more "follow" the microscopic contours, those little peaks and valleys, and harden over top, in their shape; vs filling them in and making the surface smooth again....
If you get the chance, please ask him if he thinks that's possible?
Asking those questions took place over a couple year period. I should've written down which companies I talked to and their replies, but it was just an thought at first, a curiousity... Only after receiving a couple "that could work" answers has it grown into a post worthy question lol
5StarCustmSolutns
5StarCustmSolutns
Almost Heaven, WV
forgive my ignorance... what is ppf??
edit: Nevermind, that was lazy of me lol.. Paint Protection Film! And it's available in Matte too! This has potential?!?!
5StarCustmSolutns
5StarCustmSolutns
Almost Heaven, WV
"Allegedly" the ceramic coatings that claim to be for a Flat Matte or Satin finish follow those rough surface contours?
If so, I would think that Ceramic Matte coatings share some similar properties with Gloss Clear Blenders. Which I cant begin to explain on scientific level. Just know that they use some type chemical which, on molecular level, melts the surface of the existing gloss clear, allows it to accept the new clear, and re-levels together as one smooth surface.
If Matte Ceramics coatings truly do this, then they would have to either absorb into the surface or be thin yet sticky enough to coat the peaks and valleys and stick to them long enough to harden? If that makes any sense??
5StarCustmSolutns
5StarCustmSolutns
Almost Heaven, WV
Yeah, I just stopped and started at it for a good 20sec... Then went in close and blasted off all that would come off. It's currently got a piece of white vinyl wrap over it. Not sure how I'm gonna remedy yet? Thinking either: salvage yard hood swap? -or- Sand and paint? But white again? or paint hood and roof flat black to match all the plastic panels and bed covers on top surface of the back end??
A few years ago I filled in all the open cavities on the underside of the hood with closed cell foam and Raptor lined the entire bottom surface for sound and surface protection. Swapping out hoods would mean I'd have to do that over again, adding 5-6hrs to the 5-6hrs of going to get one and the ___(however many) hours to get it on straight
I think I'm leaning towards the flat black option? I put my 3mo of planning into motion yesterday by ordering long(er) travel control arms and several other parts that should increase off-road capabilities... (honestly, it should completely transform the truck but Im trying temper expectations)
Heres a pic I found months ago when trying to see how my Av might look with LT suspension. This guy went with a compete fiberglass front end swap(fenders and grill). This front end is technically designed for the Silverado but I don't know how anyone will ever notice that with all the other eye candy he's got goin on lol
Reb03lb7
not how that works, at all
matte finish simply diffuses light instead of reflecting it. there are no peaks and valleys
again, just get a matte PPF wrap - do not wreck a factory paint job trying this
5StarCustmSolutns
5StarCustmSolutns
Almost Heaven, WV
Hey sorry delay... Im not sure what you're referring to that doesn't work that way?
If you mean flat and matte finishes? They diffuse light by way of their imperfect irregular top, or surface, layer. On a micro level.... -vs- Gloss finish under magnification much more resembles a solid smooth surface, reflects more light, gives it the shine, etc etc
petethepug
Michael
SoCal
My buddy’s 13 3500 white hood lost a couple of quarter size paint pieces on his white hood this year. He wrapped the hood with an eagle logo.
Spent $800 to have my shop take the clear down to paint on our 08 YXL black hood that was peeling. The respray of the new clear got the remaining clear to start peeling too. The entire hood had to be totally stripped again, painted & cleared.
After the shop perfected the technique to respray the peeling clear, they respray’d the sunroof area visible from head on for $500. The rest of the truck was color sanded and buffed out for $800.
The resto pro’s were amazed at how thin the paint and clear was on a factory paint job. They said it would eventually need a total respray because GM did not use enough product.
I had the option to respray the entire truck black, wrap it, restore it or part with it. The option I chose was resto & sell only because I discovered GM’s Gen 3 metallic paint last longer, Esky Platinum dashes don’t crack & 09 6.2L don’t have AFM and drink alcohol. It was better in the long run to switch from an 08 Denali to an 09 Esky.
a1parrothead
