MOOG 81246 Front Coil Springs
INACTIVE ACCT
I am wondering if anyone knows if the MOOG 81246 are the Z71 front coil springs, that in a way, match the MOOG 81069 springs in the rear? I have the 81069's and wish to complete the setup. The rear has added an extra inch of rake, so before I do a level, I want consistency in the geometry of the suspension hoping the front raises too because of a HD compression rate. I have a 2007 Tahoe LT. Any other viable options are in play also. Thanks in advance!
I
INACTIVE ACCT
Sweet. Ordered them and they should be here tomorrow. I am just wondering now, with that front setup… and possibly adding a lower strut 2” spacer, if I will need UCA’s due to the 3” total lift on the front geometry.
Thoughts?
Dustin Jackson
@Prometheus_Lens I would install the spring and run it to see how far it lifts it first but yes you'll need some upper control arms and maybe a diff drop if you add additional lift but honestly the upper control arms don't solve geometry they only solve clearance and the ride will degrade the more off center the lower control arm is.
I
INACTIVE ACCT
There are also these: https://www.amazon.com/gp/aw/d/B07D3HC3L1?psc=1&ref=ppx_pop_mob_b_asin_title
Wait, those probably won't work with the GMT900, unless the front suspension is compatible.
Here are the GMT900 versions: https://www.amazon.com/Spindles-Ext...ty+Suspension+Advantage&qid=1726145808&sr=8-3
I dont know if I want to go this route and combine the two (as one comment on amazon read). If I do add a lower spacer, I might go simple and get a front diff drop bracket for axle angles.
Unless I just use these spindles as the lift mechanism. Have you heard of ppl just using the lift spindles for leveling? And is there any safety items to consider?
I
INACTIVE ACCT
UPDATE: My MOOG springs are being installed tomorrow, which after measurements, will dictate if I go with a 1.5" or a 2" lower strut spacer. I did however, replace my sway bars with some Belltech's bought off of American Truck. Very pleased with them!
Trey Hardy
If it gets up to around 3” or more upper control arms would help a lot with the ride quality I threw out my rough country arms and ended up running fabtech uniballs because they were the same price just about as the cognito control arms but allow more travel beings it’s a uniball so it made the ride smoother in my experience especially paired with some good coil overs
I
INACTIVE ACCT
I have my eye on the UCA's from Freedom Offroad. I love to peek at reviews and they are up their for my Hoe. When I had my 09 Ram, I almost went with them over the Mevotech's I eventually bought.
Trey Hardy
Their supposed to be good as long as your not doing any serious mudding uniballs will give you the better ride though in my opinion and regardless of crowd saying they don’t last as long as ball joints mine and my buddy’s have lasted for years (3-4) on mine 5-6 on my buddy’s and he beach rides a lot no squeaks no play just holding up strong and fabtech uniballs are one of the cheaper options (500-600$) over cognitos at
(800-900$)
I
INACTIVE ACCT
(800-900$)
No beaches where I live lol. Bit my intent is to do some geo-landing and hit some mild trails for camping. In essence, kind of my bug-out vehicle apart from the wife's van, lol.
JamesinAbilene
